Canon EOS 400D / Rebel XTi Digital Camera Logo
L
L Michael Rahilly Posted on Nov 29, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Busy flash picture and 3484 code
When powered up, camera LCD screen will display a flashing box with the flash symbol and the word busy, Also displays a 3484 code. Flash will not always pop up and when it does flash flashes intermittently.
Harrie
Level 3:
Top Expert:
  • Canon Master 6,746 Answers
  • Posted on Nov 20, 2014
 Harrie
Canon Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285567
Points
83153
When showing busy, most of the time the camera detected an error, but can't find out what is causing the error.
Try the normal "reset" method as follows:
Like a cold boot for a computer, the camera can be "rebooted"
follow the following steps:
Switch of the camera and remove the battery.
Remove the memory card and the lens. (if possible)
Recharge the battery. Wait till the indicator on the charger indicates the battery is fully charged.
Check all contacts, if they are clean and shiny. Contacts (from battery and memory card, only to be cleaned with a dry cloth or cotton swab(s).
Reinsert the battery, reinsert the memory card and re-attach the lens.
Then switch on the camera.
If this does not help, contact a certified Canon repair centre.
5 Related Answers
Anonymous
  • 148 Answers
  • Posted on Dec 23, 2007
SOURCE: "busy" in all modes except non-flash setting on 300d
bad memory card most likely.
try reformatting card in camera.
try battery out for 10 seconds for full reset if that does not work.
may have a problem writing to card.
you can also try another card. cf i believe on that camera.
good luck.
mark
Anonymous
  • 42 Answers
  • Posted on Mar 07, 2008
SOURCE: Getting "busy" display on all modes except no-flash mode...
The "Busy" code will be on when the camera trys to use a flash and waiting for its charging action. Upon completion of charging the mechanism returns a signal to the camera to fire the shutter.
That means now your camera has something wrong on the flash unit and the camera waits for some certain time frame to finally determine it cannot complete a photo-taking command.
An "ERR 99" denotes that this kind of error has not been encorded explicitly and needs investigation services.
Anonymous
  • 155 Answers
  • Posted on Apr 09, 2009
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Anonymous
  • 5 Answers
  • Posted on Aug 07, 2009
SOURCE: My Canon EOS 1000D wont take photos, viewfinder flashes busy
Maybe you drop your battery and they have electronic components inside that could be spoiled, if is that the case, try to change the battery, it appeares to me that the ammount of current the battery is sending to the component is very low even thoe it seems to be fully charged that's why the camera is unable to display anything and the "busy" warning is blinking all the time, I hope you find this usefull.
Anonymous
  • 2335 Answers
  • Posted on Apr 15, 2010
SOURCE: Canon Rebel XS says it's busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Canon 450d lcd will not turn on at all, viewfinder says busy, and camera will not take pictures
In menu option C.Fn-12 you can choose to switch the display off (or on) when you switch on the camera. The display stays off even if you switch of and on the camera.
Press the button <DISP> and switch off the camera, while the settings for recording are on the screen. After you switch on the camera, the LCD screen will be switched on again.
Please refer toy your english manual, I had to translate, because I don't have the English version.
The busy symbol appears when taking a picture when flash is used. why?
Most likely it is charging up the flash capacitor. The busy symbol should turn off when the flash capacitor is fully charged.
1helpful
2answers
'busy' message in view finder won't take a picture
how can you download and update firm ware when you cannot see anything on the screen?!!!!
Canon EOS - no data on LCD and viewfinder says busy
I hope that helps.
My 9 month old camera will power up, focus and flash however it will not take the picture. When looking through the view finder, "busy" flashes when trying to take the picture. The battery is fully charged...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
1helpful
I hope that helps.
3helpful
2answers
The only problem with SD card download stuff is that the LCD screen has to be working. If that is part of the problem, how can the instructions be followed?
1helpful
Canon 40D LCD Wont come on buSY flashes in view finder
Okay, this is simple. Your camera can take several pictures at one time in a burst. However when you release the shutter button your processor takes a second to actually SAVE the pictures to the card in the camera. One thing than has helped me in my wedding photography business is to buy the fastest speed cards I can find. It significantly reduced my "busy" time.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
