Hi
Pls give me the solution that how can I remove bellows message from my PC
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
without reinstall because my outlook express has about 5000 mail if i reinstall Windows XP then i will lost all of my mail so pls help me
" you may be a
victim of software counterfeiting"
The message is displayed because your version of windows is not genuine. here are some steps to make your windows genuine
1 . start > run > " regedit" (without the quotes of course)
2 . Go to the key:
HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\WindowsNT\ CurrentVersion\WPAEvents\OOBETimer
and doubleclick on it.
Then change some of the value data to ANYTHING ELSE
delete some, add some letters, ..just change it! now close out regedit.
3 . Go to start > run > "%systemroot%\system32\oobe\msoobe.exe /a" (again, don't type the quotes)
4 . The activation screen will come up, click on register over telephone,>next> then click on CHANGE PRODUCT KEY, enter in this key:
JG28K-H9Q7X-BH6W4-3PDCQ-6XBFJ and give update.
(Now automatically window will return back to activate by telephone mode and ask for activation code,just ignore and exit that window it's done)
the only permanent method to remove that message is buying an original version and i do recoment that, than the steps above........
THERE ARE NUMBER OF METHODS BUT FOR YOU THESE 2 METHODS ARE GOOD
1) METHOD:-
TRY SYSTEM RESTORE.
2) METHOD:-
2.1) LAUNCH WINDOWS TASK MANAGER.
2.2) End wgatray.exe Process In Task Manager.
2.3) Restart System In Safe Mode.
2.4) Delete wgatray.exe from c:\Windows\System32.
2.5) Delete wgatray.exe from c:\Windows\System32\dllcache.
2.6) Launch RegEdit.
2.7) Browse the following key HKEY_LOCALMACHINE\SOFTWARE\MICROSOFT\WINDOWSNT\CurrentVersion\Winlogon\Notify.
2.8) Delete The Folder "WgaLogon" and all of its component.
2.9 ) Reboot System.
3.0) BE HAPPY NOW.... AND NEVER EVER INSTALL WINDOWS GENUINE ADVANTAGE
NOTIFICATION IN WINDOWS UPDATE OTHERWISE YOU HAVE TO REPEAT THE DAMN
PROCESS AGAIN.
IN ORDER TO THAT FOLLOW THIS
START--> CONTROL PANEL--> AUTOMATIC UPDATES --> CHOOSE THE OPTION """"""""""""Notify me but don't automatically download or install them"""""""""""
When
u use this option whenver your system detects any new WINDOWS UPDATE
choose the updates which u want to install... DONT INSTALL WINDOWS XP
SERVICE PACK --3.
I want to u to remove the message , you may be a victim of software conterfeiting.from my computer, because it has change the my screen background to black.
same with me.....pls help me to remove a victim of software conterfeiting fm my com.
same with me too...pls help me how to take out this.you may be a victim of counterfeiting..?pls let me knw how thank you
If your copy is genuine activate Windows again if not look at the link
The Get Genuine Kit
If you dont want to sped money on Windows then use Linux there are several distributions my favourite isUbuntu.
http://www.howtogeek.com/191207/10-of-the-most-popular-linux-distributions-compared/
Download Ubuntu Desktop
Pls u i want u to remove the message,you may be a victim of sofware counterfeitng from my computer,because it has change the my screen background to black pls help me i wnt to fix it thank you
