Its a Mongoose Meteore Team 2008 aluminium frame
You'll need to take it to a welding shop to have it properly repaired. Look at how much a similar "used" aluminum bike frame cost, then use that as a gauge to set a cost limit. Say for example a similar used bike frame cost $100 from a bike shop. If the welder charges $80 or more, then you might as well spend the extra $20 and replace the cracked bike frame instead of getting it welded. Of course, you'll need to take the parts off the cracked bike frame and transfer them to the used bike frame, assuming you know how to do it yourself. If you need to pay a bike shop to do the job, then having the welder repair the crack is cheaper.
SOURCE: Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
SOURCE: My wife has a Schwinn
I HAD THIS PROBLEM ONCE.SOMEONE PUT THE WRONG SIZE POST IN THERE...NOT ME.BE PREPARED TO RUIN THE POST TRYING TO GET IT OUT.I STUCK MINE IN A VICE AND SWIVELED THE BIKE ITSELF.PULLING AND TWISTING AT THE SAME TIME.TAKE AS MUCH OFF THE BIKE BEFORE YOU DO.THE POST WILL EITHER COME OUT OR IF IT DOESNT,TAKE IT TO A BIKE SHOP AND SEE IF THEY CAN HELP.GOOD LUCK
SOURCE: I have a mongoose XR-50, I need the seat post,
Search engine: "30 mm seatpost"
Fixya is not intended to be a source for answers to general questions that can found by general search engines.
