Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.] Logo
A
Anonymous Posted on Nov 27, 2013
Does a black and decker 7180 go into reverse - Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.]
1 Related Answer
Anonymous
  • Posted on May 14, 2008
SOURCE: Black & Decker Drill (Motor does not work on Forward switch but it is ok on reverse)
Scraped the drill and bought a new one for $20
How can I reverse the direction on the drill?
Above the trigger there is a black slide switch that will reverse the direction if its in the colckwise direction the richt side is pushed in if counter clockwise the left side is pushed in.
2helpful
Motor runs backwards
Hi- Sorry to hear this. This would be a defect and need to be looked at for warranty. This occurs if the wires are connected in reverse. Please follow the link to locate your nearest service center for warranty assistance.
blackanddecker com
Thank you
Black & Decker Customer Care
Black and decker 7120 in reverse
Turn the drill over and push the switch all the way in.
How do I change my black & decker electric drill to go in reverse or forward? As you can see I'm tool challenged. Kathleen
The switch near the trigger that toggles left or right controls that.
Good luck with your project, Kathleen.
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Top Black & Decker Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
