When I plug in the battery charger, it does not fit snuggly into the port. I bought a replacement charger, but that hasn't solved the problem. The battery is also new. Is there any way I can charge the battery other than using the port?
SOURCE: Acer Battery chaging problems
Seems like a old problem, but does the laptop work without a battery? possibly the powerjack on the computer is loose.
if you have already solved this problem do share with the world how you solved it.
SOURCE: Acer charger plug no longer charges
It sounds like the connector on the motherboard has come loose. Don't continue messing with it as you will make it worse. You might be able to have a technician resolder the motherboard connector. It is a common problem with a variety of laptops and a lot of times can be fixed for a modest fee.
SOURCE: the battery won't charge
check the output of the charger and see if it is charging if so the conector might be bad does the plug wiggle when it is plugged in? it should feel very solid
SOURCE: My battery is not charging. I bought my Acer 5738g
Remove battery, replace and ensure contacts are clean. If wont charge then battery is dead. Get a new battery.
SOURCE: My acer 5735 won't hold a charge. Seems to charge (green light)
if it doesnt hold a charge its degraded and will need to be replaced . people dont realise that keeping a laptop plugged in damages the battery
