Sarted receiving printed fax report daily for the last month. Information reads - NOTE: Blocked calls are not displayed on this report. For more information, see Junk Fax Report and the caller ID History report. Don't understand why this copy is printed automatically daily. Want it stopped. HP6310 All In One
SOURCE: BLOCKED CALLS
If you subscribe to a caller ID service through your phone provider, you can block
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
number in the blocked fax numbers list, the fax is not printed.
Set the junk fax mode
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
service through your phone provider, or do not want to use this feature, you can turn
off this setting.
To set the junk fax mode
▲ Some models have a Block Junk Fax button. Depending on the model you have,
do one of the following:
• Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
• Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
I have use LEO Privacy, which helps me to block all spam and unwanted calls and lock all private apps. I suggest everyone to download it and check it out hide photos/videos feature. LEO Privacy Applock Boost Hide Android Apps on Google Play
