Question about Panasonic KX-T7630 Corded Phone
Hi, at reception i have my switchboard - Panasonic KX-T7640 and we have various extensions. Now at reception like in the other offices i also have a seperate phone on my desk with an extension no. On my switchboard that particular extension it shows that the phone is available to use, however if i try to phone through to it or put a call through to it the red light does not go on, but it shows on my switchboard screen the word 'busy' and i get an engaged signal. It's as if the line is busy. However if I pick that phone up i can dial other extensions and make outgoing calls. It seems to be blocked from the switchboard to that phone. Please help. Thanks
  • Panasonic Master
  • 3,335 Answers
It sounds as if you have DND - Do Not DISTURB
feature turned on...
There should be a light or indicator on the STATION itself
giving the DND status.
Carnac the Magnificent
Posted on Apr 07, 2017
6ya staff
SOURCE:
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Posted on Sep 12, 2008
Anonymous
  • 4 Answers
SOURCE: We have KX-T7730, want to stop incoming calls going to a different extension, so that the main calls just go through reception phone
try 408
Posted on Feb 26, 2009
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Hi i have a panasonic KX-TES824 installed with 2
A Panasonic Analog PTS ring sound is not adjustable, however, the cadence is. An outside call rings with a single ring, an internal call is either voice announce or a double ring. The digital phones from Panasonic have either 8 or 30 different tones, but that's a different system.
Carl
Posted on Nov 21, 2010
Richard Van Brunt
  • 225 Answers
SOURCE: Hi there, my business uses
The introduction message is usually setup as a custom service menu. You need to determine if this is the case by logging into the message managers mailbox and listening to find the current greeting. To log into the message manager mailbox, call voicemail, dial #6 then *98(for 2 digit mailboxes) or *998(for 3 digit mailboxes) or *9998(for 4 digit mailboxes), enter password followed by #. Once in the message managers mailbox, press 5 to record messages. Your introduction message could be the company greeting or a custom service menu. Press 1 for the company greeting and follow the prompts to listen to the greeting. Press 3 for the custom service menu, then enter the custom service number 1-100( in your case start with 1 until you find the current introduction message) and follow the prompts to listen to the message. Once you have found the current introduction message record your new message and save.
Posted on Dec 28, 2010
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: I bought five Panasonic KX-T7730X
A TD system is a DIGITAL phone system and the 7730 phones are ANALOG. I don't know what X means, but I guess they're not from the US :-). Anyway, the ANALOG phones need 4 wires to work, instead of the 2 that the digital phones have. If your installer was lazy and didn't cross-connect 4 wires at the frame or put in 4 bridge clips on each jumper, then you don't have a voice path. Or, XDP is turned on and you'll have a bit of a problem.
If you have an IM and a PM for the TD system, you can find the wiring diagram and the instructions to read the XDP status. Quick answer is the first 2 of every 3 pairs will run to your phone. If you start with a digital phone in the port first, turn on XDP and plug a single line set into the XDP port, you will get dial tone (may have to dial 390 or 391 to enable/disable the XDP twinning) and that dial done will be different from the digital phone. If you don't get dial tone, your first pair wiring is missing. Fix that, turn off XDP and you 77xx series phone will now work in the port.
Carl
Posted on Jun 24, 2011
How to stop / edit all incoming calls ringing to other 2 extensions at the same time?
What phone system are you using?
I will gladly show you how
KX-TEA/TES/TA series or KX-TDA/TDE/NCP series
Oct 25, 2015 | Panasonic KX-T7633 Corded Phone
How can I change the direction of incoming calls to various extensions?
Just a guess but maybe changing the connections for the lines on the switchboard. This may also change their numbers though.
Apr 10, 2015 | Panasonic KX-DT333-B Digital Phone
How to assign extention bottons on a KX-T7636
Do you have programming software?
I will gladly guide you through.
Feb 06, 2013 | Panasonic KX-T7636W Corded Phone
Hi I am working at the Switchboard. I have a Panasonic KX-T7730 that is seven years old. Every office has an extension code and a name. I want to change the display names of the extensions as it still...
This has to be done on Ext 101, or whichever phone is the programming phone. Press program *#1234. Then enter in 004. Press Speakerphone. It should be asking for a jack number. You can press speakerphone again to go to the first ext. Spell out the name using the keypad (2 is A, B and C and so on). When done press the autodial/store button. Then you can press speakerphone to go to the next phone. To get out of programming just pick up and hang up your phone or press the program button.
Aug 30, 2011 | Panasonic KX-T7730 Corded Phone
Hi I have panasonic kx-t7730 and I have a problem. We have two lines but only rings on switchboard. We also Use cordless panasonic phone but it does not ring unles i transfer to it. I have already done...
In a TA series, the ringing is programmed in system programs 408-410. You go to the main phone, enter system programming, and select those options and turn on ringing per line and per extension.
Carl
Sep 03, 2010 | Panasonic KX-T7730 Corded Phone
Answering the phone
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 to answer external incommincg calls. To answer extension phone press 4 followed by the extension number.
Thank you
Nov 19, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7633-B and KX-T7640
I'm looking for a user manual of a KX-T7640 phone, but it doesn't seem to exist. Who can help me?
Jan 29, 2009 | Panasonic KX-T7633 Corded Phone
The incorrect name being displayed when you use a preset number
The side buttons is programmed as extensions
To change the extension names follow these steps :
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
For assigning a person name to the extention
Jun 18, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
180 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
