There is usually a switch on the back of the DVD player to choose either channel 3 or 4. You will need to use the TV's remote not the direct TV remote. To change the source or input to the correct inpit mode on the remote select input then select the input mode that you plugged your DVD into ( tie. HDMI 1 or 2 ) then turn on DVD that should do it
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from magnavox.com, you will need a model number.
go to walmart ang get an rf converter, you plug your dvd into the converter, then run a coax cable from your converter to your tv, put your tv either on channel 3 or 4 and presto. they only cost a few bucks. http://www.radioshack.com/product/index.jsp?productId=2103095 this is a high dollar one, they got em cheaper at walmart. dont forget to rate. :)
does your tv have a scart socket or is it pre scart, if it does, and you connect the dvd player via the scart then the tv should auromativally switch to av when the dvd player is switched on. failing that, if you have no scart, then the only way you can watch dvd is by connecting a flylead from dvd player to tv, (take out antenna and put it in that socket) and then start a search if you can, normally the buttons for this are behind a flap somewhere on the tv. if you have no scart or a way of tuning tv, then i dont think you can watch dvd through that tv
your best bet for this problem is to rearrange the way you have your direct tv and dvd hooked up to your television. a lot of the time you can plug the dvd player into the input/antenna in jack on the back of the receiver. that way you can watch all the channels you want AND be able to watch dvds without having to unplug and replug stuff in. more than likely you'll have to push an input or tv/vcr button in order to switch between watching direct tv and dvds, but it's a lot simpler than switching chords around.
if you live in the uk you should be able to get a all in one controll to tune the channels in but if you can get those two channels you should get the rest but you will need to tune them in first this cant be done with out the controll
It seems you have already try everything We might suggest< I dont know if you have tried using the video and audio outputs in the dvd/vcr combi unit conecting them to the audio and video imputs of your tv and the selecting maybe one of the AUX channels to watch it,If you have a tuner problem in your tv this will be a way to bypass it and control the channels from you combi unit.We would like to know the outcome,please let us know.
