Question about Nikon D40 Digital Camera
Nikon D40 Flash not popping up and not always flashing.
My flash used to automaticly pop up when it was needed. Now not only does it not pop up but when I pop it up it does not always flash. I lookd in the setting on menu but I don't see a place that I can make it reset. Any suggestions?
  • Z Laws May 11, 2010
    What setting do you have it on on the rotary dial on the right?
6ya staff
SOURCE:
Anonymous
  • 78 Answers
SOURCE: Nikon D40 will not take a picture.
when you pusht o take a photo does it display an error on the top screen? make sure the lens is locked in including checking the ring on the lens next to the camera base.
Posted on Jan 01, 2008
Anonymous
  • 111 Answers
SOURCE: Nikon D40 will not flash
The lightning bolt icon in viewfinder blinks when flash is not ready, this can happen if flash doesnt pop up all the way, or if flash strobe tube is bad.
Posted on May 17, 2008
Anonymous
  • 7 Answers
SOURCE: pop up flash nikon D80
I'm not sure of your problem, but if I understand it correctly, the flash does not pop down on its own, you just push it down and it locks down.
Posted on Jul 21, 2008
Anonymous
SOURCE: nikon d40 flash won't fire
My d40 did the same thing and the guy at Wolf Camera said a sensor is bad. The falsh was up but every time I focused it tried to pop up the flash again but it would not fire.
I had 2 options. Send it off for 8 weeks to Nikon at a $240 minimum or buy a flash attachment for $100. I chose the $100 option.
Posted on Oct 20, 2008
Steve5
Steve Grezoux
  • 423 Answers
SOURCE: Histogram pops up on Nikon D40
When you are viewing images with the histogram showing, press the down arrow on the command dial and the screens will scroll through various overlays until you reach the viewing screen you want.
Posted on Sep 05, 2009
Flash won't pop up
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
Flash not popping up - did i push something?
Make sure you're not shooting on no-flash auto mode. Also, in P, A, and M modes you'll have to press the flash button on the side of the camera by the lens mount in order for the flash to pop up. If it's not popping on regular auto mode, make sure you don't have it disabled in the menu.
Jun 12, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
Nikon D40 built-in flash...
Hi and thanks for coming to FixYa.
You can set the parameters for the manual flash in the Custom Settings Menu. Select Full to set the manual flash adjustments.
Hope this helps. Let me know if you have any questions in a comment.
Rob
Feb 27, 2009 | Nikon D40 Digital Camera
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
May 16, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 flash won't fire
If lightning bolt icon is blinking in viewfinder, flash is not ready. Either flash isnt popped up all the way or flash strobe tube is bad.
May 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 - The built in flash will not ppo-up in auto mode. The only time it works is the manual modes. Are there any settings I don't know about. I'm calling it defective and will return it the store.
With the command dial set to "auto", try to take a shot in low light. The flash should pop up automatically. You can't manually pop it up with the flash button in the auto mode. If it won't pop automatically in low light, then it certainly sounds defective.
Apr 16, 2008 | Cameras
Pop-up flash
make sure after popping up the flash, you didn't change the mode into "no flash" mode....an easy way to check is put the flash back down, then proceed to take another photo. If the flash pops up again but did not flash, you have a faulty camera (assuming battery level is at least until the 1/3 mark).
Dec 26, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera Logo
266 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
