I recently purchased this decode software for my business and it seems to be doing very well. I ran your serial number and received a code of 5894. Would be grateful if you would let me know either way if this code worked as I want to keep track and make sure I got my money's worth buying this software. You can reply/comment here or email me directly at [email protected]. Thanks and I hope this works for you....
SOURCE: Blaupunkt RDS car radio code needed
First make sure that the code has not been noted somewhere
within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be
removed from the dashboard (and if you are lucky, someone may have written the
code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL
plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL
CASING
There should be a 14 character number beginning with
BP++++++++++++ and also a model number beginning with
7 *** *** *** so quote everything you can find
Also quote the MAKE of CAR
SOURCE: gm unlock codes for factory rds radio. it has cd
There is a code to get from the radio, then a Technicians will call GM to get the actual unlock code. Only takes a few minutes.
See this link to do it yourself. They have a 1 hour turn around...
GM Radio Unlock Codes
