No heat from my oven everything else is working
If it's gas, there is about a 99% chance it is the igniter, (to see the igniter you will have to remove the bottom panel from the oven- at the back of the oven you will see a small stick shaped piece with two wires connected to it. Oftenn, but not always, bad igniters are visibly cracked, or sometimes even shattered) and if it is electric, there is about a 99% chance it is the element (you will probably be able to see a whitish discolored crack in the element). Both are fairly easy to change.
You will have to look online for replacement parts most likely, just be sure to get the model number from the sticker on the oven (usually on the inside of the bottom drawer if there is one) when you look up the part.
Also, when changing parts, UNPLUG the unit.
