May be oil port on saw clogged. Remove side cover, remove bar and chain. Remove giude plate if equipped. Check to see if small oil hole on saw is open and clean. You can start the saw with side cover removed to see if oil is coming from oil hole or not. If it is coming from oil hole when running the problem is most likely dirty bar .If bar is dirty check to see that groove is clean and the oil hole along the edge of bar is clean also. The hole is at same end of bar that attaches to saw.
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
SOURCE: homelite chain saw --first time user--do you mix
In the compartment closest to the chainsaw bar, you need to fill this with chain and bar oil. Any good name brand will work fine.
In the other compartment you need to add a mix of petrol and oil in the ratio specified for your saw. If unsure, 25:1 petrol/oil ratio should be ok.
SOURCE: just got a homelite 33cc
Yes you do! The ratio is 50:1 fuel to oil. Be sure to use a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to use fresh fuel and mix the two in it's own container. Be sure to shake the container thoroughly each time just before refueling to prevent oil starvation in the engine. Don't make up more than one gallon at a time unless sawing is your business. Hope this helps!
