The computer has a missing sm bus controller driver. SM bus controller. PCI bus 0, device 31, fuction 3. On microsoft ACPI- complaint. PCI bus 0, device 2, function 1. PCI bus 0, device 2, function 0. when I install the driver I get a fail to install.Error in DLL: supported smbus hardware was not found in the system. But it is missing the drivers. How do I fix this?
SOURCE: need driver
you have to download the inf(chipset) drivers for sm bus and most probably the pci device is the sound or any other card in the pci slot check it then download accordingly
SOURCE: The PNP information
Try this for the audio
Direct download link - ftp://202.65.194.211/pc/audio/WDM_R201.zip
if that doesn't work try here
get the "Windows 2000, Windows XP/2003(32/64 bits) Driver only (Executable file)"
lets get these sorted one by one, so let me know if that gets your sound working.
SOURCE: I want to V2000 laptop driver.
First, Right click my computer, click manage, then go to device manager from the opened window.
Then, right click on your 5 specified components, and click update driver. this should automatically try to update them online.
Failing that.... the following is the long winded way of doing things!
This site should do the trick. look at the exact model number on the bottom of the laptop, it should say;
HP Compaq Presario
V20zzxx
[where zz is 2 numbers for the exact model number]
[where xx is 2 letters in lower case]
(you'll see what i mean when you click the link)
select the relevant link from here and click to download
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=432985
SOURCE: driver missing
We had the same exact problem but with a Compaq Pesario V6000 series notebook. Ours had to do with the NVidia System Management Controller but was listed in the device manager as a coprocessor. Kind of a bland description.
Solution: Downloaded and installed NVidia System Management Controller from here. Hope this helps.
