It is a 7 cycle machine mdl# lat8106aae. it fills normal but all cycles engage forever unless moved manually. originally it started with just the draining cycle .
It's either the timer is faulty or the lid switch is broken. If it fills and agitates but dos not spin and drain it's the lid switch. If it spins and drains when manually advanced to that setting your timer is bad.
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
OK, Duh..... I guess there is about a 2 to 3 min. delay for the liquid soap dispenser to fill up and disperse the soap into the washer tub. After that short cycle is complete the fill cycle engages and fills at normal speed.
your lid switch is broken you need to replace it look on the lid of the unit you will see a plastic pin that pushes down on thwe switch when it closes there are 2 screws holding the switch in place but you will have to remove the cabniet to change the switch
i suspected as much. hope we are right
