SOURCE: Strange Flicker with HDMI components
Reset the yamaha player to factory sttings and check if the issue still exists ,unplug all the cables and replug the cables if the issues still exists its the problem with the Yamaha receiver, please get it changed as its a new player................................
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
SOURCE: I have a yamaha receiver with HDMI outputs for
Does the Yamaha have HDMI inputs? Usually you would connect the directv and dvd player via individual HDMI cables to the Yamaha (input)and then the Yamaha (output) to your TV also via HDMI.
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
