5.9 cummins turns over and won't start, tried changeing filter and have fuel up to there. Shows trouble codes P6033, P2509, P2269. what are these code and what should i try next.
this is a 2003 dodge ram 2500
I LOOKED THEM UP AND THE P2509 SAYS ECM/PCM POWER INPUT SIGNAL INTERM & P2269 SAYS WATER IN FUEL CONDITIONI LOOKED THEM UP AND THE P2509 SAYS ECM/PCM POWER INPUT SIGNAL INTERM & P2269 SAYS WATER IN FUEL CONDITION
You can't post conmments that contain an email address.
I do not have Cummins codes so I would consider replacing the injectors or taking it to a Cummins service centre to have it fixed as the parts will not be cheap if not diagnosed correctly
autoshutoff relay or clogged fuel filter..also diesels have a hard time starting when its near zero..need to add a cetane boost to the fuel as it can gel up..about a quart per 50 gallons..also need to look at the glowplug circiut or preheater and see if its working..
loosen one fuel line to one of the injectors, try to start the truck and look for the fuel to spray out of the line. it should spray rather hard if the injector pump is working right. if it just dribbles or trickles out you have a weak pump.
nwbombers.com
Research the trouble codes.....my '01 had a similar problem, turned out to be the CPS (Cam Position Sensor).
Easy fix.....10mm nut and unplug/plug in and reset codes and your done.
Dealer item.
your code is PCM/ECM power input signal intermittent. this is ussually a sign of a bad connection whether it be in a connector or a short or brake in a wire.
