Video Game Consoles & Games Logo
My ps3 only says connection error 80001000B and wont let me go on network settings
5 Related Answers
Anonymous
  • 7191 Answers
  • Posted on Mar 01, 2010
SOURCE: ps3 wont connect to playstation network.error code
Yes. There is a worldwide issue with the Sony Network today which might be due to system maintenance and upgradation.
Sony is working on the problem and the problem will be rectified soon. Kindly wait for further announcements from Sony. Your system should work normally when the issue is fixed.
For details and status updates, click here
Thanks for using FixYa.
Anonymous
  • 61 Answers
SOURCE: won't connect to playstation network
Check for updates, this is actually a known issue going through the PSN network and is still going under updates and maintence. It should resolve itself within 24 hours, just keep checking it as well check for updates. I know a update has come out, check to make sure you have the latest verison.
DrakeTech
Anonymous
  • 55 Answers
  • Posted on Mar 07, 2011
SOURCE: error 8001000b wont allow me to connect to the
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the rounter. This is usually done my typing the router's IP address on your browser. ie http://192.158.0.1
3. Locate a tab for FILTERS
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point rounter will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
Read more: http://www.ps3news.com/forums/ps3-guides-tutorials/how-fix-wireless-internet-error-8001000b-ps3-98772.html#ixzz1FxUHQxte
Hope this helps. Please Rate
Ironfist109
Iron
  • 3018 Answers
  • Posted on Apr 21, 2011
SOURCE: error code : 80023121... it
The PlayStation Network is down at the moment. Sony Entertainment is working on this. There is nothing wrong with your system.
From the PSN - "While we are investigating the cause of the Network outage, we wanted to alert you that it may be a full day or two before we're able to get the service completely back up and running. Thank you very much for your patience while we work to resolve this matter."
Regards, Tony
Anonymous
  • 54 Answers
  • Posted on Apr 23, 2011
The Play Station network is currently down due to "an external intrusion" on their system. They are working to get everything up and running again.
2answers
Error 8013031b for ps3. tank's
According to Sony, these are the steps you should take to fix this error code. It has something to do with the way your system obtains its IP address from the network you are connected to. This should fix it.
SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > WIRED CONNECTION OR WIRELESS >
WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
17answers
New play tv wont work via remote play on my psp
To make Play TV on the PSP via the Remote Play work
watch the instructional video here
and detailed information here in full-color
be aware that this whole thing depends on the firmware version of both PSP and PS3
tip
PlayStation 3 ERROR CODES
Complete PS3 Error Codes:<br /> <br /> <br /> 0710102 - DNS Error; No DSN server available.<br /> <br /> 8013030 - System Error due to failed update download<br /> <br /> 80010001 - Major Error , Game ability stopped<br /> <br /> 80010006 - An error occurred during the start operation (corrupted folding install)<br /> <br /> 80010007 - An error occurred during the start operation (during disc swap tests)<br /> <br /> 8001000B - it happens when trying to establish wireless connection<br /> <br /> 80010017 - Can't start BlueRay Game<br /> <br /> 8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown<br /> <br /> 8001050D - An error during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again<br /> <br /> 8001050F - Hardware failure. Cannot update firmware or connect to internet.<br /> <br /> 80010510 - Will not play games installed on the hard drive<br /> <br /> 80010514 - Possibly reading blu-ray disc problem<br /> <br /> 80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again<br /> <br /> 80023101 - Unknown<br /> <br /> 80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server<br /> <br /> 80028EA5 - User cannot connect to PS3 network<br /> <br /> 80028EA6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.<br /> <br /> 80028EA8 - Seems to mean unable to authorize isp account details<br /> <br /> 80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,<br /> <br /> 80028F17 - Ps2 disc Boot Error , An error occurred during the start operation; Ps2 game swapped using the eject function and then play pressed quickly - Backup ps2 game inserted again<br /> <br /> 80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).<br /> <br /> 80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it<br /> <br /> 80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error<br /> <br /> 80029023 - Exchanging Key Information exchange has timed out<br /> <br /> 80029024 - "The attempt to obtain an IP address has timed out".<br /> <br /> 80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card)<br /> <br /> 80029501 - connection<br /> <br /> 80029509 - When the PSN network is down for maintenance.<br /> <br /> 80029513 - This content cannot be accessed on your account (80029513)<br /> <br /> 80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them)<br /> <br /> 80029564 - Downloaded game will not install<br /> <br /> 80029751 - warhawk wont start but eveything else seems ok<br /> <br /> 80029945 - Can't playback burn BD movie<br /> <br /> 80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )<br /> <br /> 80029C68 - Corrupt data usually on external device<br /> <br /> 8002A10B. It shows up when I try to view my friends trophies, profile etc.<br /> <br /> 8002A10D - Unable to Add friend in XMB<br /> <br /> 8002A4A6 - Cannot load game to play online<br /> <br /> 8002A515 - Error Signing in<br /> <br /> 8002A524 - connection<br /> <br /> 8002A548 - Unable to remain logged in - either to game or server<br /> <br /> 8002A705 - Unable to connect to server/host. Check router port configuration.<br /> <br /> 8002AD23 - Unknown<br /> <br /> 8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually configuring your PS3 IP info. Try disabling medai server connection in the PS3.<br /> <br /> 8002B241 - DVI has no audio.<br /> <br /> 8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game<br /> <br /> 8002F994 - Too many people downloading the update (download it later on)<br /> <br /> 8002F997 - Can not update XMB firmware<br /> <br /> 80030001 - Deleting messages from inbox<br /> <br /> 8003041F - An error occurred during the copy operation (using media server)<br /> <br /> 80030517 - It seems to happen when you copy large media files.<br /> <br /> 8003051E - Game will not save<br /> <br /> 80030920 - An error occurred during the copy operation, the file may be corrupt or there isn't enough memory (Try copying data from original source)<br /> <br /> 80031150 - "Setting information is corrupted.Press the x button to repair and restore default"<br /> <br /> 80031601 - Error Creating Account<br /> <br /> 8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the connection drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only WPA or none<br /> <br /> 8013013D - connection<br /> <br /> 8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security<br /> <br /> 80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.<br /> <br /> 8013030F - Access Point not detected<br /> <br /> 8041040F - Communication with the server failed. A dsn error has occured.<br /> <br /> 80410418 - DNS Error<br /> <br /> 80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.<br /> <br /> 80710016 - Playstation Network is down.<br /> <br /> 80710092 - "An error has occurred. you've been signed out from the ps network" , "Media Server Error: A network error has occurred (80710092)"<br /> <br /> 80710101 - Connection error<br /> <br /> 80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router<br /> <br /> 807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error<br /> <br /> 8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and completely remove the power cord. Shut off your modem/router, for approx. 5 minutes, then turn the modem back up first and let it sync. Then turn the router back on (if you're using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection<br /> <br /> 80710541 - The connection to the server timed out.<br /> <br /> 80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ<br /> <br /> 80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured<br /> <br /> 80710B23 - PS3 Network is Down or PS3 Network is too busy to respond<br /> <br /> 80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode<br /> <br /> 81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
5helpful
Getting error code 8071053d tried rebootin ps3 and internet not working still wont let me play online
The error code indicates that the PS3 is unable to contact the Playstation Network Servers. This may be caused by the PSN (Playstation Network) being under excessive load (often a result of new, significant DLC being released) or a problem with your router or ISP (Internet Service Provider).
  • On your Playstation 3, go to the Settings menu, scroll down to the bottom and select Network Settings, then select Internet Connection Test. If you do not see success for Obtaining IP Address and Internet Connection, then there is a problem with the networking between your PS3 and the internet.
If you both of these connections prove successful, but you are still not able to sign in to the PSN, try:
  • Contact your ISP and see if they have some sort of outage in your area or are somehow hindering your connection to the Playstation Network.
2helpful
Sony PS3 ERROR CODE 80710092?
here are some of the ps3 error code that might help you in the future..
80023101 - Unknown
8002AD23 - Unknown
1helpful
2answers
Error 8001000b wont allow me to connect to the playstation 3 network anymore. everytime i turn the ps3 on it says error 800100b on the screen then i go to the network settings to try and connect and the...
2answers
Wot error is 80710723????
You have a network/router error. First go to settings, then Network settings, then internet connection settings. If you have a wired connection connection 1 - Custom, then manual settings, then auto detect, then automatic, then Do not set, then manual, DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220, then auto, then do not use, then enable.
If you are using a wireless connection 2 - WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
and if neither of these works then try turning off your modem for a few minutes and restarting your ps3 =)
MY PS3 WONT CONNECT TO THE ITERNET BECAUSE OF DNS ERROR 80710102 HELP PLZ
get your own internet connection. dns error means it's not able to connect to the internet. if it is your own connection, restore your default settings and powr cycle your internet. check with your IT and check your network firewalls/settings
Dns error 80710102
try mving your ps3 around into verous places around the room and try to find an internet connecion. you can go to settings, network settings, then settings and connection status list and it will show you how much internet you have.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
