The dealer should not charge you to do this. Call around and ask what they can do for you. The security system on these cd units is to keep people from stealing them and putting them in their car like you did ( minus the stealing part ) The radio needs to be reprogrammed to match your vin code. I would just suggest that you call around see what happens.
Unless you had replaced the BCM on your Aztek there is no reason you will need a code to unlock your radio. You can not unlock the radio by just entering a code. The dealer has to program it and it is done threw the internet. Approx $95.00 will program your Aztek.
I have a civic and as far as the unlocking code I checked in the glove box and there is a little white sticker with the numbers that I had to put into my radio to unlock. Not sure with the sunfire though...you could always call up your dealership and they'd probably have it.
I had the same problem the day after having my drivers side window motor replaced. The brain surgen who replaced the motor didn't notice the door lock/unlock switch didn't work when he put the door back togeather. Bypassing it until they got another switch the next day solved the problem
I had the same thing happen about two years age. I had the drivers side window motor replaced and the brain surgen didn't notice the lock/unlock switch didn't work after he put the door insides back togeather. Bypassing, then replacing the switch solved the problem. Look for a short somewhere.
