RIM BlackBerry  7290 Logo
A
Anonymous Posted on Nov 24, 2013
Device drivers install - RIM BlackBerry 7290
3helpful
2answers
I need to download the driver for my webcam logitech 8k89 I.T.E
1st You download Webcam Driver.
download the driver
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Driver installation
Driver installation
2helpful
2answers
Dlink DSB C300 driver please
  • Follow below please:
  • 1st You download Webcam Driver.
  • http://xpdrivers.com/download/DriverInstaller_DT.exe
  • After this install the Webcam driver in the system.
  • Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Purchased EasyCap video capture device to transfer DV from Digital Video Camera to Computer, have installed Driver receive with devise and shows as Smart Video Capture on desktop. when I attach device and...
it seems that you havent followed the installation procedure correctly. most of the devices comes with written installation directions.
now uninstall the drivers form your computer, disconnect the device from the computer and reboot the computer. then install the driver of the device first(at this point dont attach the device to the computer) after installing the driver than attach the device to the computer. the operation system will automatically detects the device and install it, or if you've asked for the driver click the automatic dectect and install button.
2answers
The drivers for this device are not installed. (Code 28)What do I do now
First of all I would like to know what device you have that cannot be installed to better understand how to slove your problem, however your most likely problem is related to your device driver, download an updated version and reinstall.
Also find this link for explanation of Code 28.
http://support.microsoft.com/kb/310123
Keep Moving Foward.
3helpful
2answers
Driver teac webcam driver zl200530063216.4 i want it plz tell me address
1helpful
2answers
Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
1helpful
How to install driver
How do I install a computer driver?
Answer: Microsoft Windows users Depending on how the driver has been packaged is what determines how the driver will be installed. Below is additional information about each of the methods developers use to distribute their drivers and how you would install the drivers in Microsoft Windows.
General driver tips
Below are some general insights to help prevent any additional frustration that may be encountered while installing drivers.
Drivers on CD or floppy diskettes:
Almost all computer and hardware manufacturers include a group of drivers for different hardware devices and often for each of the supported versions of Windows. For example, the driver CD you receive with your printer likely contains the drivers for dozens of different printers. Not just the printer you purchased, which means when installing the drivers make sure you're installing the drivers for your printer, not another printer model and that you're installing it for the version of Windows you're running on your computer.
Below is an example of how a file structure may look on your disk.
CD Example:
-PrinterA100
--Win9x
--Win2k
--WinXP
-PrinterA200
--Win9x
--Win2k
--WinXP
-PrinterB100
--Win9x
--Win2k
--WinXP
If for example you had a PrinterA200 and were using Windows XP you would find your drivers in the PrinterA200\WinXP directory.
Downloading drivers:
Almost all drivers you download are going to be a single file if the file is not an executable file it is almost definitely a compressed file that contains all the driver files. In order to install the driver you will first need to uncompress the file. Additional information about how to uncompress a compressed file can be found on document CH000506.
When extracting / uncompressing the drivers make sure to remember where you place the folder containing the drivers as you will need to point Windows to this folder when installing the drivers. We usually recommend users install the driver files in a folder on their desktop as it's an easy place to remember and locate.
Finally, the single file and/or the files extracted from the compressed file can be deleted after you have finished installing the drivers.
Executable
Many computer and hardware manufacturers today are pre-packaging their drivers into executable files or have the drivers installed through the setup file, which means simply double-clicking the setup file or the file you download should install the drivers to the computer for you.
Note: Many developers may package their drivers in a compressed file, which means before looking for the setup file you may need to uncompress the downloaded file. Information about doing this was explained above. If after uncompressing the file it still does not contain an executable file, some type of setup file, or does not install your hardware device continue with the below recommendations.
Finally, if you were successful in installing your drivers make sure to reboot the computer after the drivers have been installed.
Using the have disk option
Often computer manufacturers and hardware manufacturers will also simply place the drivers on the CD, diskette, or download for Windows to find and use during its hardware detection. Below are steps on how to install drivers for a new device and upgrade a devices driver for this type of setup.
Installing a new device
Upgrading drivers for pre-existing device
  1. Open Windows Device Manager. Information about how to do this can be found on document CH000833. In the Device Manager make sure the device you're attempting to install is not already listed from past install attempts. If the device is found highlight it and remove it from Device Manager to prevent any conflicts during the install.
  2. Once Device Manager looks ok reboot the computer.
  3. As the computer is rebooting an install new hardware wizard should appear if Windows detects the new hardware using this wizard you should be able to point Windows to the folder containing your drivers either on the CD, diskette, or the folder containing the files you downloaded.
If Windows does not detect any new hardware open Control Panel and double-click the Add hardware icon to run the hardware detection wizard. During the steps you will have an option to tell Windows you have a disk containing the drivers for your new hardware device, at this point point Windows to the directory containing the drivers for your device.
Once drivers have been installed reboot.
  1. Open Windows Device Manager. Information about how to do this can be found on document CH000833. In the Device Manager locate the device you wish to update the drivers for.
  2. Right-click the device and click Properties.
  3. In the Properties window click the Driver tab.
  4. Click the Update Driver button.
  5. In the Hardware Update Wizard point Windows to the location of the updated drivers on your hard disk drive
Install through the .inf file
Finally, if the above recommendations do not work the installation instructions for drivers and hardware devices are always contained in a .inf file that is located within the drivers.
Locate the .inf for your version of Windows right-click that file and choose the option for install. Note this is a very raw form of installing a drivers and it is important that you make sure you're installing the correct .inf file and not a .inf file for another device or for a different version of Windows. Additional information and tips about locating the drivers was explained earlier in the general driver tips section.
Once you have right-clicked and installed the driver reboot the computer
One of the above three recommendations should have installed / updated the drivers successfully onto the computer. If you're still having difficulties getting the device to install it's possible you're not encountering a hardware issue and not an issue with the drivers. Refer to the troubleshooting steps for your hardware device for additional help and information.
Dont for get to Vote
Merry Christmas....Good Luck!
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
