ASUS P5N-E SLI Motherboard Logo
sunil patil Posted on May 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mercury PI845Z drivers
Dear Frnd,
I have mercury PI845Z mainboard, 2.4GHz processor, NVIDIA GEFORCE5200 Graphic card
1) When i first installed the chipset 82845G\GV\GE\PE\GL graphics controller driver, and after that installed graphic card driver and rebooteing system, the windows XP2 starts with blank screen. But it works in safe mode. so my dealer suggest to install graphic card driver first and then chipset driver, it reaaly works but when i play The Prince of persia the 2 thrownes it quited pausing the game after 5 to 7 minutes but when resuming the game the quiting starts again.
2)Also my usb on this mainboard works very slow at about 512KB/s. so anybody suggest me the good usb driver for PI845Z mainboard
Anonymous
Level 3:
  • Master 818 Answers
  • Posted on May 07, 2009
Anonymous
Master
Level 3:
Answers
818
Questions
0
Helped
459643
Points
2161
Go here
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N-E%20SLI)
Anonymous
Level 3:
  • Master 413 Answers
Anonymous
Master
Level 3:
Answers
413
Questions
Helped
148074
Points
1208
Check for the speed support of the board and graphic card there might be aclash of speed or try installing the hardware after os installation and then graphic afterwards motherboard utility
1helpful
I purchased mercury PI845Z motherboard. For one year it works good, but after that when I play any video (flv,mp4...) full desktop flickers, and when I start video call then also it flickrs. I have 1G
Hello try to renew the vga driver from here:
http://www.mercury-pc.com/downloads_list.php?productid=857
Or run the intel driver update utility from here:
http://downloadcenter.intel.com/
You can also add a better graphic card, on the mainboard for better performance.
This mainboard has the AGP slot, for adding a graphic card.
Just make sure you have the driver, for your windows system.
Good luck
I have no graphic driver for amd athlon(tm)64 processor 3800+ 2.40ghz for windows xp
Take a look at my guides they are as follows:
How to install Graphics Drivers, Nvidia and AMD Radeon!!!
As you will need to install the drivers for your graphics card to get a better resolution and video quality! You will need to know the make of graphic card you are using either Nvidia or ATI/AMD Radeon
How to Download AMD Processor Driver!!!
As you can download and install the latest Processor drivers for your computer.
Happy Computing!
Thanking you
damnor01
Every high framerate game i play causes the graphics to stutter, i have a msi h55 motherboard, i5 quad core processor and 8 gig of ram. could you tell me what might be causing this problem?
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
Use my guide to install the latest drivers for your graphics card. It is entitled How to install Graphics Drivers, Nvidia and AMD Radeon!!!
The section on Nvidia Graphics Cards applies to you.
Your computer components may be overheating, install as many fans as your computer chassis will allow. Use 120mm fans if you can, Cooler Master SickleFlow 120mm fans are Excellent.
The cooler you can get your computer to run the better it will perform and the longer it will last.
Download a program called Hardware monitor.
You will then be able to run this program in the background while you are playing your games, then exit the game and check the maximum temperatures.
CPU temps should not be over 65 Deg
Graphics Card Temps should not be over 70 Deg
The H55 computer mainboard is not really a gaming mainboard, it is more of a media setup.
If you keep every-thing cool I suppose you might get away with it.
You may need to give your mainboard an upgrade to P55, Socket 1156
Get a good make I prefer ASUS.
Happy Gaming, For the Win!
Thanking you kindly
damnor01
1helpful
Cannot find info or the card on how to install drivers and afterburner disk. Video card is MSi N220GT-MD1G. says the device is 0a20.. onboard number is N1996. Just need to find card info on installing,...
  • Manufacturer: MSI Computer Corp.
  • Part number: N220GT-MD1G
General
  • Device Type Graphics adapter
  • Enclosure Type Plug-in card
  • Interface Type PCI Express 2.0 x16
Processor / Memory
  • Graphics Processor / Vendor NVIDIA GeForce GT 220
  • Clock Speed 625 MHz
  • RAMDAC Clock Speed 400 MHz
  • Video Memory Installed 1 GB
  • Technology GDDR2 SDRAM 128-bit
  • Memory Clock Speed 810 MHz
  • Features Nvidia PureVideo HD technology, Solid aluminum capacitors, Nvidia CUDA technology, Nvidia Lumenex Engine, NVIDIA Unified Driver Architecture (UDA), Nvidia GigaThread technology, Dynamic Overclocking Technology (D.O.T.) Express, Nvidia PhysX-Ready, MSI Dual CoreCell Technology
  • Max Resolution (external) 2560 x 1600
  • API Supported OpenGL 3.1, DirectX 10.1
  • Digital Video Standard Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
  • HDCP compatible Yes
Expansion / Connectivity
  • Interfaces 1 x DVI-I (dual link) - 29 pin combined DVI, 1 x VGA - 15 pin HD D-Sub (HD-15), 1 x HDMI - 19 pin HDMI Type A
  • Compatible Slots 1 x PCI Express 2.0 x16
go to here for drivers
http://eu.msi.com/index.php?func=searchresult&keywords=N220GT-MD1G&table=download
hope this helps
John
    1helpful
    I want the VGA driver for AMD Semprom 2800+ Proccesor
    The VGA driver can be downloaded by using either the Graphics Card or Mainboard model number. The Processor doesn't need a driver to operate.
    Use www.nvidia.com and go to driver downloads, then select the Graphics card information.
    Now save and run the install.
    damnor01
    Dear sir, can i use geforce fx 5500 graphic card in mercury mainboard PI945GCM ?
    Unfortunately the Geforce FX5500 is an AGP8X card and the mercury mainboard PI945GCM only supports PCI-Express 16X graphics cards.
    You can find a list of all the available Nvidia graphics cards for your motherboard here: http://www.fixya.com/support/r6784358-list_compatible_nvidia_pci_express_16x
    You can find a list of all the available AMD/ATI graphics cards for your motherboard here:
    http://www.fixya.com/support/r6789140-list_compatible_pci_express_16x_graphics
    4helpful
    5helpful
    Unable to launch direct3d-a compatable graphic card was not found
    All your drivers will be in the following locations.
    Motherboard drivers:
    http://www.mercury-pc.com/downloads.php
    select your motherboard by the type of processor and download the drivers
    nVidia drivers latest:
    http://www.nvidia.com/Download/index.aspx?lang=en-us
    NOTE: before installing any new drivers, uninstall all the old drivers.
    remove all your motherboard drivers and graphics drivers. then first install the motherboard drivers and finally install the graphics drivers.
    all will be around 100 to150 MB make sure you use a download accelerator and have enough bandwidth.
    Best cimpitable nvidia graphic card for my mercury PI945GZD mainb
    you must check your motherboard manual if what VGA card is compatible in your mothetboard.. or check it to the website of the manufacturer of the motherboard in order to know the compatible Components for your board..^^^^^^^
    Pliz let me know ofthe least comp specz that can go with an nvidia geforce5200 128mb vga card
    Any 8X VGA equipped ATX Motherboard will be able to handle this card, even if it is 4X it will usually clock down. 250 watt Power supply is recommended. AMD Athlon or Pen 4 processor.
    Top ASUS Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Paul Bade
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
