RCA HD52W56 52" Rear Projection HDTV Logo
Posted on Oct 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv is zoomed in and I can't get it back the way it was to begin with. Is there a reset or something?
Anonymous
Level 2:
Sniper:
  • Expert 140 Answers
  • Posted on Oct 10, 2007
Anonymous
Expert
Level 2:
Sniper:
Answers
140
Questions
0
Helped
105132
Points
449
On your remote control in the center, the left and right arrow buttons will cycle thru the available screen formats: 4:3,zoom1,zoom2,cinerama,16:9
The picture is too big for the tv and seems to be growing bigger. how to reset picture size
On some remotes there is a button with Aspect/Zoom, try pressing that until you get the desired picture.
2answers
The Screen is zoomed in and we dont have a remote or a manual for the tv what can we do
not sure what model tv you have but there should be a menu on the tv. seach thru it and select the zoom option if not. shut and unplug the tv for 20 minutes that will reset it back to factory settings for you let me know if this helps!
Samsung TX-P2730 TV, top and bottom of picture outside of visible frame in Normal Mode (Not Zoom Mode--Zoom makes it worst). Need to ID Vertical Adjust control. Not on Remote, not on back panel of TV. I...
The reason you can't find a vertical width control is there isn't one..all that is done through the main board and the tcon board in the TV...you may have one of those boards bad...there really isn't a way to troubleshoot this without some quite fancy test gear. You could try updating the firmware and do a hard reset on the TV for starters, wondering if its in the zoom mode.
My proscan tv went into wide screen....everything shows up bigger. how do I get it back to normal? By wide screen, I mean if there are 2 people sitting at a table talking on screen at opposite sides of...
It sounds like you accidentally enabled a zoom feature or something similar.
Most remote controls should have a clearly labeled "zoom" button or a "picture size" option. If not, go into your TV's menu and look for something zoom related.
If this doesn't work, just go ahead and toy around in your TV's menu. I strongly suggest writing down the default settings so you can go back to them if you screw something up.
Permanent zoom
try hard reset or manufacture reset, on the tv (unplug for two minutes, and see if the settings have changed back to default
2answers
Our Cinema series 32" TV is stuck on ZOOM and I can't get it back to regular. There is a ZOOM button but it doesn't seem to do anything. Ted Thank you
unplug tv for five minutes then return plug....now press and hold the tv power button for ten seconds(This should reset it!)
2answers
I need to get rid of the block on my tv screen
Turn the text in the closed caption mode off.
RCA HDTV zoom settings
I had the same problem when I bought my TV. Looking at your remote try pushing the left arrow button. The left and right arrows work the zoom feature. It also sets the picture format. Try it and post your results.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
