If pilot stay lit, then thermocouple is working.
If pilot will light, then you have gas. If pilot goes out when pilot button is released, then thermocouple is next suspect.
Thermocouple tip must sit in pilot flame.
The pilot light heat applied to two different metals inside thermocouple causes small current.
The current travels back to gas control valve through copper line.
If the gas valve receive this current, then a magnetic switch stays open and allows gas into the gas control valve.
The magnetic switch is on the end of the red button you push down when lighting pilot. Essentially the red button is an override to the magnetic switch.
If the gas control valve does not receive the current, then the magnetic switch does not stay open when you release the red button.
When replacing thermocouple, note that it is not screwed very tight into the gas control valve. Finger tight + 1/4 turn. If it is overtightened, then the small thermocouple current shorts out against the gas control body.
If you need further help, Iām available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
