My son forgot his passcode and i tried to do a reset and the green guy came up but nothing else happend after.i wasnt abel to type anything or nothing,
SOURCE: help how do hard reset my proscan tablet plt7035 i
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Try to hard reset it. This will take it back to just out of the box state
press and hold volume - button While pressing the power button.
If this does not work contact the retailer.
Testimonial: "Thanks! Tried the power with the volume button to no avail. Looks like it's a goner :)"
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
