LGL75c I have a lgl75cc smart phone my screen quit working bout mos ago. Tried everything including hard reset. Turned it off and just other day turned back on but bout 1/2days of use it quit working again. It didn't get wet or anything else. I dropped in the dirt at the arena were I ride. But wasn't stepped on or even completely covered. Please help to get working again.
SOURCE: Everything works but no display
Ah! My friend. you are lucky that you ask the right person. I have fixed so many V551 with LCD defect so this symtom is usual on v551 and most Motorola Flip phones. As you know, the construction of the LCD cable has been designed by a long ellectric thin wire and one side will connect into the main and CallerID smaller LCD and the other end will connect to the main board and the part in the middle will stuck inside the hinge where the flip will apply a lot of force for the function of open and close. for a long period of usage, it will either worn out the middle part of the cable or loose the connection of either side which cause loosing display. That is why you can call and receive but cannot see anything. The simple thing is open the case and check first at the main board side for any bad contact and tougher the other side is inside the main LCD. If you find both side are still good in connection then the middle part is bad due to flipping so many time of the user in order to open and close. YOU THEN NEED TO REPLACE THE NEW LCD. I have two solutions to help you in this case: 1) View on the link below for the instruction of how to open the housing. http://sbarth.dyndns.org/seiten/rahmen.php?nav=motorolahandy Sorry the link is in German but you can look at the picture to follow. 2) Or email me at [email protected] if you want me to repair the phone for you. I will charge you for only $10.00 for labor fee and $5.00 for shipping. I am sure to make your phne back to normal or your money back. My shipping address is below: JOSEPH DAO P.O. BOX 390307 MOUNTAIN VIEW, CA 94039 USA If you want other way to help, let me know. I am sure you will be happy with your phone back to normal. I hope this help
SOURCE: Samsung SCH - U340 won't turn on
hold 9 while powering the phone up i had the same issue then i did some googling and it worked for me :D gald i could help. now refer to me as king mike bc i solved your problem :D
SOURCE: My Samsung U520 randomly turned itself off; is there a way to hard reset this phone?
check the charger , it is changing, change the battery it migh be bad
SOURCE: I have the same problem!!!! I just dropped mine 2 hours ago!!
http://www.fixya.com/support/r3771170-phone_water_damage
SOURCE: New phone. Bought it on sale at Frys. The
Hi mshedgehoq You need to take the micro sd card out of the phone put it into your computer and make a copy on the sdcard from your computer. Your husband did a hard reset should not have wiped out all the information. If you go to my files look for lost.dir and see if all the informationd is still in their. Now your husband didn't do anything to the phone it is thr way of all dtoids to put your information in the lost.dir ok Hit that menu and you should see all your information. The hard reset did it's job which is to wipe the phone competely out of data like brand new.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
