Question about Kitchen Ranges
Oven temp settings is wrong
When I try to cook at 400 degrees I have to set the oven at 300 degrees.
    Novelist:
    Scholar:
  • 157 Answers
Possible you'll have to replace the thermostat. Easy job...just have a peek at it.
Posted on Nov 24, 2013
6ya staff
SOURCE:
catriver
Ron Marek
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
bigg t
anthony james
  • 640 Answers
SOURCE: Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Posted on Aug 15, 2007
Anonymous
  • 146 Answers
SOURCE: Gas oven not heating to temp
You more than likely have a defective oven sensor. For some reason the sensors tend to go after a few years of use. It is in the upper right or left hand corner and looks like a probe sticking through the inside back of the range. When you open the door you just look towards the top back left or right corner there are 2 screw securing it to the back. Gently pull it forward. You will see a couple of small wires feed into as you pull it in. On most you will see a plug in connector come through the hole if not you may have to just splice the new one in.
Posted on Dec 21, 2007
Anonymous
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
Mike Carew
  • 969 Answers
SOURCE: I have a GE XL 44 gas oven. The oven does not
REPLACE HEAT SENSOR
Posted on Nov 12, 2009
Why does my oven temp go down sometimes 50-100 degrees? I set it at 400 and check food and it's not done. Check temp and it's not what I set it at
thermostat problem normal cooking is done in the 150 to 280 range
at 400 you are getting to self cleaning temp and any cooking done there will burn
Jul 03, 2017 | Kitchen Ranges
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Lg lst5651sw problem
One burner is out either the top or bottom.
Nov 04, 2013 | Kitchen Ranges
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 16, 2009 | Ovens
The oven will turn on and get warm (not up to set temp)not as hot as it should. I no longer hear the forced air noise from the fan/blower from the back of the oven? It will not cook food, in the time frame...
is your power setting up allthe way (10) is it a convection oven also? microwaves dont usualy have a temp. setting unless there is a probe pluged in inside oven to a jack on inside wall of microwave microwaves can also get old and lose power if so you can get cheep ones at wallmart
Jun 17, 2009 | Microwave Ovens
Stuck at 288 degrees
NO PARTS REQUIRED!!! DON'T PAY FOR A SERVICE CALL!!!
After a power outage, my wife's grandmother said she could no longer set her over to 300, 400, 450, whatever..
I went over to troubleshoot.
I couldn't figure out why everything seemed functional and why I couldn't set the over to higher than 288 (and thought, that's a rather odd number)... until I realized that that 288 degrees C = 550 degrees F which is the max the oven can do.
The power outage reset the computed back to celcius instead of fahrenheit.
Save them a ton of money... cause this could have been an easy cash grab to some cook out there.
May 01, 2009 | Kenmore Kitchen Ranges
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Oven cooks at 400 plus degrees when set at 350 degrees
If your problem is temperature do this;
Press "options" Then press "6". Then press "3" to increase or "6" to decrease temp.
Then press "start" to end the calibration.
If you recently used self-cleaning you could have a thermal overload fuse problem.
Feb 23, 2009 | Whirlpool SB160PEE Gas Single Oven
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
