Computers & Internet Logo
Posted on May 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't turn on - PS light on but no PS fan
Turned the computer off now the computer won't turn back on. The powerlight on the Hipro HP-D3057F3R PS comes on but the fan does not. could the AC fuse be blown and if so where is the fuse?
Anonymous
Level 2:
  • Expert 38 Answers
  • Posted on May 07, 2009
Anonymous
Expert
Level 2:
Answers
38
Questions
0
Helped
13365
Points
150
Surely sounds like the power supply is in need or replacement, or fuse replacement at absolute least.  the fuse that you will be in search of will be located inside of the power supply unit.  Use caution when working inside the power supply.  If you don't see a fuse in the power supply, OR you come to find that the fuse is not damagaed then you will likely need to replace the power supply.
Regards,
Joe
Hipro hp d3057f3r up to how much can my pc have ram?
The very best thing to do is to go to crucial.com. They will take a look at your motherboard, and tell you how much more you can add, if any, and will sell you RAM which is compatible with what you already have.
Ibm ps 1
Most likely it's a power issue.
My computer won't turn on
when it is blinking red it means its in sleep mode. at that time the fan is turned off by your computer to save power. Press the power button oce again and u should have it up and running.
Hp m7590 fans won't start. Green light is on power supply
Try connecting the fan to another fan plug in on the mother board usually there are two or three of them . Then go into the BIOS [press delete while booting] and make sure it is turned on
Looking for power up issue help please. Attempted to put comp. in to sleep mode by pressing keyboard button. Nothing happened. Went to windows xp start button and hit standby, nothing happened. Did this...
few things to try you can disconect the hdd the dvd rw drive and anything elce conected to it appart from the motherboard and moniter then try again (just becouse you tryed to check the psu it my well still be completly broken ) i would probly suspect the motherboard in this case thought i would try a new psu first as this cost less (10 pounds from ebay) hope this helps ps reset the bios and cmos too
I have a HIPRO HP-305 power supply. The green
the 4 pin connector is for cpu power. the hipro power supply are not very reliable.
8helpful
2answers
Hipro HP-d3057f3r computer power supply broken?
I have the same problem. I found this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph06788&product=12455#bph06788_section_2
  • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
  • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
  • 0helpful
    When is the Hipro HP-A2007AE power supply cooling fan to be on?
    The fan should run constantly. It needs to be replaced. Otherwise the power supply will shut down when it gets hot. It can usually be replaced, but if the supply is cheap, just go out and get a new one.
    Grand Canyon Tech
    Grand Canyon Tech
