Kitchen Ranges Logo
Posted on Nov 28, 2017
Re: Kenmore electric range, model 790.9661. While
Re: Kenmore electric range, model 790.9661. While baking in oven it started beeping and flashed F10 ERR. Told me to press stop/clear to stop beeping. Didn't work had to stop by turning off circuit breaker. Oven does this each time I try to use. What is F10 ERR. Want to avoid paying for service visit if I can repair myself.
Ty Herstine
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 28, 2019
Ty Herstine
Contributor
Level 1:
Answers
Questions
0
Helped
920
Points
Take a flat head screw driver and gently pretty the door. The temp decreases fairly rapidly and then the lock is disabled. Good luck!
1 Related Answer
Anonymous
  • Posted on Aug 12, 2009
SOURCE: f10 error on kenmore elite electric built in model 790.4907
Try unplugging the unit from the wall, wait 5 minutes and replug back in. I had same thing happen to me a few months ago. I had to leave my stove/oven unplugged for 24 hours to finally get it to reset itself. It is working fine now.
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 • Ovens
1helpful
While baking muffins, taking the 2nd batch out of the oven I noticed a smell like an electrical burning smell. Just then the oven started beeping and flashing a F08 and F07 code. I tried to turn the oven...
Looks like you have a runaway temperature problem.
I will guess that the oven is electric and the top burners are gas, as it is with most dual fuels.
Like like an oven sensor or board problem. The quickest way to find out what the error codes mean is to Google it. Then re-post your question for a more specific answer.
The error codes should also be in your customer user manual.
Hello- my oven is a kenmore model 790.94224409 and I keeps getting overly hot and shutting off 10 minutes into baking. It beeps and i get a F10 error type code. Every time i open the range door, it...
Sorry to read about your problem, I hope this helps you out.
you have a defective temp sensor
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
1helpful
2answers
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
3helpful
Kenmore model 790.9621 electric stove error code F10. The oven heats up on bake (set at 400 degrees) then goes into f10 mode; and seems to be heating up more. Answer for problem??
it is the bake relay sticking--on the eletronic oven control board.i tried to buy the relays but,no luck.must buy the eoc board-great engineering
F10 error on kenmore elite electric built in model 790.4907
Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
