I have an Mp-F70 and I can format a 1 GB SD card with the according software on the PC but when I download new stuff on the card the player won't read it
I think the problem were some of the files.
They were downloaded to the MP3 ewith out name.
I downloaded them from another computer and it worked fine....
maybe just a glitch
If your computer has a built in card reader you can put any photo back on the card from your computer by dragging and dropping the file to the drive letter that is your SD card. If you're trying to recover lost photos from a SD card Google "card recovery pro". It's a free program that will read your SD card and restore as many photo's as it can.
FRIST, download the 83 pics u have and save them. your camera may be reading the internal memory. go to setup and change to sd card option. If that doesn't do it, and it's already looking at the SD card. Format the card. NOTE: see first line again!!!
Step One: Tosavedata, useEASEUSData Recoverysoftware(freeversion-1GBof datarecovery).how: 1.Download and installEASEUSData Recovery 2.ChooseCompleteRecovery-Next 3.Choosethe drivemicro SD-Next 4.Save thedatato the harddisk(max.1GB) 5.Because ofyourmicro SD2GB,repeatthe process ofrecovery(repeatstep 2, 3,4) Afterall data issecure, do theprocess of removingthe micro SDpassword
Step Two: The first alternative- use thesoftwareHPDriveKeyBootUtility 1.Downloadand install thesoftwareHPDriveKeyBootUtility 2.Then, doubleclick the filecp006049.exe 3.Ifyou are usingWinXP,double clickthe filecp006049.exe-select Install. 4.Ifyou are usingWinVistaorSeven,double clickthe filecp006049.exe- selectextrack. 5.Then, open the program"HPDriveKeyBootUtility orhpdkbu.exe"-Next-selectdrive-Next-Create neworreplaceexitingconfiguration -Next-Harddrive-Next-Create newfile system -Next-waituntil theprocessis completed-Next-Finish. 6.Remove themicro SDfrom the USB port,theninsert it again. 7.Quickformatmicro SD(FAT file system) 8.Restoreall data,to themicro SD.
The second alternative- usesoftwareHDDLow LevelFormat Tool 1.Download and installHDDLow LevelFormat Tool 2.Selectmicro SD-Continue 3.ClickS.M.A.R.T-clickGet SmartAttributes 4.ClickLOWLEVELFORMAT-clickFormatthis device 5.Waituntilthe processis complete- pressOK 6.Remove themicro SDfrom the USB port,theninsert it again. 7.Quickformatmicro SD(FAT file system) 8.Restoreall data,to themicro SD.
I hopethisinformationhelps.Thank you forusingFixYa!
If your aim is to repair a corrupted SD card so that you can use it to store files then proceed to step #2.
If your aim is to recover the files on the SD card without erasing them, proceed to step #5.
Insert the SD card into a
digital camera card slot and choose to format your card. If this doesn't
work then move on to the next step...
Place the SD card into your computers SD card slot.
Right click on the SD card drive letter IF it appears and choose to "format."
If this doesn't work, proceed to the next step...
4:You will need to go to the website
http://www.sdcard.org/consumers/formatter/eula/
Here you will download, install, and run the program to format your SD
card. This is the most advanced step of the three, but most likely to
work 99% of the time.
5
If you want to recover files ON your SD without erasing them, then you need to download and run the software on this site.
http://www.cgsecurity.org/wiki/TestDisk_Download
This is the best free software available for this type of problem.
If the Sandisk 1 gb has 233 mb after formatting, then the card is usually bad and must be replaced.
Try doing a complete formatting again.
If that does not work, delete partition and try doing formatting with a tool like the one below. If the software below does not fix the problem, then replace the card.
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
Hey Guys yes I am from South Africa Just bought the SD 2 GB ScanDisk sd card - Same Thing Pathetic to say the least! Anyways - Thanx for the comments what i have learned from this is that its not just ME with the problem, and I must say I feel better! Kodak C310... well you cant compare it with the big boys... Cheers Stan
Ps: formatting the card in your pc does not fix the problem with the camera, I tried it.. The card works fine on my Garmin
