I think I can help. Usuly the doors have been swapped around in this case. look closely at the freezer door on hinge side. there should be a small metal piece that covers the hinge to prevent anything from jamming hinge. this shield also serves as a spacer. this is what sets the door at the correct height. if the piece is missing you can have your local appliance dealer order one for you. it only takes a few minutes ts to install. you will need to remove the freezer door to do this. Hope this helps and good luck.
You can buy door shims and install them on hinge pin.
