Apple iPad 64 GB WiFi Logo
Posted on Nov 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I tell if I have an iPad 1 or 2 - Apple iPad 64 GB WiFi
LP
Level 3:
  • Master 514 Answers
  • Posted on Nov 23, 2013
LP
Master
Level 3:
Answers
514
Questions
Helped
120682
Points
1285
Here's info from: http://support.apple.com/kb/ht5452
The (original) IPad ...
  • The model number on the back cover is:
    • A1337 on the iPad (Wi-Fi + 3G)
    • A1219 on the iPad (Wi-Fi)
  • Black front bezel
  • 30-pin connector
  • Standard SIM tray on the iPad (Wi-Fi + 3G)
  • The IPad 2 ...
    • A1397 on the iPad 2 (CDMA model)
    • A1396 on the iPad 2 (GSM model)
    • A1395 on the iPad 2 (Wi-Fi)
  • White or black front bezel
  • 30-pin connector
  • The micro-SIM tray is on the right side on iPad (GSM model only)
  • FaceTime and rear cameras
  • Add Your Answer
    2answers
    How to unlock an ipad
    If you remember the password of your iPad, it's would be easy. However, you can still refer to below steps to unlock an iPad without password.
    It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
    Method One: How to unlock iPad without password using iTunes
    • 1. Connect iPad to the computer you have synced with.
    • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
    • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
    Method Two: How to unlock iPad screen without password with iCloud
    You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
    • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
    • 2. If the sign-in window pops up, just sign in with your Apple ID.
    • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
    • 4. Click Erase (your device) in the prompt to finalize the process.
    • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
    Method Three: How to unlock a disabled iPad in recovery mode?
    If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
    Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
    iPad Air
    • 1. Turn off your iPad Air, press and hold the Home button.
    • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
    • 3. Continue holding the Home button until the iTunes logo appears.
    iPad mini/iPad pro
    • 1. Connect your iPad to your computer or laptop and open iTunes.
    • 2. While your device is connected, force to restart it.
    • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
    Now you have entered the recovery mode, and
    1. When you see the option to Restore and Update, click it.
    restoring-ipad-software-cpmn0ithqpr5j0kd3fh1ly4i-5-0.png For more details, check: How to Unlock iPad
    I need help with the passcode for my ipad
    Is there anything wrong with the passcode? If your iPad is locked and you forget the passcode, please follow the steps below to unlock it.
    1.Connect your iPad to your PC or Mac.
    2.Select your device in the iTunes sidebar, and click the"Summary" tab.
    3.Click "Check for Update". iTunes will show you if there any new version of iPad software is available.
    4.Click "Restore iPad". You can finish the restore process by following the instructions given. During the process, a recommend that tells you to back up your files will be given. You can restore your data after the process is complete.
    Now, you must have restored your iPad.
    Note: Even you bring your iPad to the Apple service center, Apple staff also need to restore your iPad to unlock it. That's to say, you need to erase everything on it.
    http://www.leawo.org/tutorial/forgot-ipad-screen-lock-password-how-to-recover-data-from-locked-ipad.html
    3answers
    My Apple iPad 2 won't update. It's running iOS 9.
    It may be too full. Check how much free space you have. Try to have approximately 3GB free. Delete things that are easy to replace like apps, or music you can download again.
    1helpful
    My ipad screen is frozen
    Hi there Lois! Try restarting the computer (and maybe the Ipad as well). It may help. If that doesn't work check out: iPad Contact Support Apple Support and press "Get started." Your issue might not be listed so click on any of the options and click "The topic is not listed." Apple has the #1 support in the world. I wish you good luck on getting the Ipad up and running.
    -Mr. W
    4answers
    How do I transfer pictures from iPad 1 to iPad 2 .
    Can you install Dropbox app on both tablets to transfer pictures? Or feel free to try this iPad file transfer program on your computer. Transfer Files among iOS Devices iTunes and PCs with Ease
    Need to download iOS 8.0.1 on my apple ipad keeps telling me it failed because I am not o internet, but I know that I am connected to the iternet what is wrong?
    if you have laptop/desktop computer you can sync the iPad with iTunes and download iOS 8.1.2 there:
    Upgrading iPad to iOS 8: Through iTunes 1. Backup your iPad
    Open iTunes. Select your iPad in iTunes and click Back Up Now.
    2. Restart your iPad and your Computer
    3. Download and Install the Update
    Go to iTunes -> Select iPad -> Check for Update -> Click Download and Update
    Whichever method you choose, the process will take quite some time to work depending on how much free storage you have on your iPad, your internet connection, and how Apple's servers are doing with upgrades. Occasionally, Apple will either not let you download the upgrade or it will fail. For iOS 8, you must have an iPad 3 or newer. This does not work with the original iPad - if something goes wrong, restart your device, and try again.
    How to Upgrade to iOS 7 on an iPad or iPad Mini
    How to Install iOS 8 When Your Device is Low on Storage need-download-ios-8-0-1-apple-ipad-keeps-u3wnnnxjlb3ct0ebur4t0xqn-1-0.jpg
    How do I know if I have to much installed on my Apple ipad
    There are free apps that can tell you everything about your iPad. You can do a search on the APP store in utilities. I use System Status. If tells you everything about your iPad including disk space.
    2answers
    Top Apple Tablets & eReaders Experts
    nexrad_chris
    NOEL
    NOEL
    John
    John
    Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
