Motor is cutting out when power switch is depressed. Toggling the switch makes it work, but you have to hold switch in very tightly, but it still keeps cutting out when switch depressed. Have cleaned filter(was hoping some dust had got caught in switch) but problem still occurring. Cannot see any obvious way of dismantling switch mechanism to ensure its completely clean. Anyone have any advice/ideas please before we start looking for repairer?
Sounds like the switch is bad. If it's not still under warranty I'd look up a replacement part.
http://www.dyson.com/parts.aspx
SOURCE: Overheating Dyson DC07
Many devices including this one have what's known as a thermal cut out.
It is there for obvious safety reasons and prevents the temperature in
the locality of the cut out from exceeding a pre-defined value.
Some of them require you to press a reset button in order to switch the
power back on and other types simply reconnect the electricity supply
when the temperature returns to normal (safe) operating limits.
The Dyson DC07 has a thermal cut out located close to the motor and it is of the "self resetting" type.
If your vacuum cleaner switches off after a few minutes the most
probable cause (there can be others) is the thermal cut out has
operated.
The first and most important thing to do is to establish why it has
operated.... If the airflow around the motor has become restricted then
it will not be being sufficiently cooled and so it will have cut out
correctly. However, thermal cut outs are often quite crude internally
and it is not uncommon for them to start cutting out at too low a
temperature. So...
Here's what to do...
(some tools may be required to complete the following so read the entire
procedure before starting. Please note this is not an absolute guide if
you need really foolproof step by step instructions... buy a manual!
But this should help)
Check all these parts for blockages/clogging before continuing...
There are now only two areas left that I know of which may cause
further blockages. One is the "whole of life filter" located under the
dust bin and the other one is inside each of those seven little cones
(cyclonic chambers) at the top of the dust bin (root 8 cyclone is
usually written on one of them). The following will require some tools
and some common sense...
If none of this revealed anything very positive... Its time to open up and inspect the motor casing/thermal cut out.
**** WARNING**** The next section requires someone who is technically
minded, has fiddly fingers patience and a basic understanding of
typical plastic goods assembly techniques. As I am not including
photo's the descriptions given can only be considered as pointers to
how to do it (I'm not writing a Haynes manual here! So if you are a cak
handed clot with little or no patience and a tendency to resort to ever
bigger hammers - take the vacuum cleaner to an independent repair shop
- explain the symptoms, tell them what you have done so far and leave it
to them!!
NB. NEVER remove or bypass the cut out. this really could be very dangerous!
I hope this is of some help... Regards to all.
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
SOURCE: hi how do you dismantle the head turbine for the
There are two (or is it three) plastic screws on the underside of it. This allows it to be partially split so you can clean the area around the brush roll.
To strip it further needs a Torx T15 bit, but I don't advise doing that unless you know what you are doing and are confident about the re-assembly.
Cleaning around the brush roll area is all most people need to do with these and that is a simple matter.
I had the same problem, there is a wire on the switch that broke off. I was able to pry the unit apart and resolder the wires, but the case got pretty chewed up in process, I did manage to get it to work though.
