Different apps like, du market; mobo genie; teekik ? keep popping up on my tablet trying to force me to download them. Installed antivirus app and the still are trying to force there way through...always interupting whatever Im doing. Please tell me how to make this stop without hitting the reset button
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase
Everything"
The following will occur:
• The screen will display COBY
• The screen will display Android
• The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target.
Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home".
The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until:
1- You have configured your Wi-Fi
2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
SOURCE: every time I open my galaxy tab. I can not access
touch and hold on pressing the home key until a task manager note will pop out end the recent tasks or uninstall the programs that u suspect making problems. my galaxy was having problems with viber and what's up communication apps i uninstalled them and the problem was solved automatically
SOURCE: can not download apps to a 4sight tablet
Check out:
http://slideme.org/
http://www.freewarelovers.com/android
