Model tfz22prdaww seems to have board in place of timer . how do i initiate a defrost cycle?.
The best way to determine what has caused a non defrosting GE electronic control model is to first access the control board. Jump terminals line power to defrost, (J4 and J9). An amp probe should be placed on this jumper wire to determine current draw of the defrost circuit. A three amp draw is what is normal for this circuit. This will eliminate checking behind the evaporator cover to determine a defective heater or over temp device (defrost terminator). Note: This test is only to check the defrost circuit. It does not initiate a defrost cycle. If the unit is in any other cycle than defrost, that cycle will continue to operate as well.
Dear customer,
Your defrost system isnt working properly. We recommend you to kindly do the following
Click on the highlighted words to know more. Thank you,,
This is a worst refrigerator I have used. The frost heater is broken again. What a lousy product.
