My singer 1120 is not stitching a zigzag stitch correctly. The top of the stitch is coming out with an extra piece of thread under the zigzag or other times it comes out with no zigzag it looks more like a honeycomb. The bottom of the stitch comes out PERFECT!!! I have tried different length and width combos settings on my machine, different tensions settings ranging from 0-3, and cleaning and oiling my machine. If anyone has any idea on how to fix this I would appreciate any input I could try!!!!! Thanks and Happy Thanksgiving!!!
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
SOURCE: I have a Singer Sewing Machine 5817C, the thread
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
SOURCE: I have recently bought Singer Quantum 9940 and I
1. Make sure your needle is correct for the fabric. Go buy some good needles in several sizes. You'll need a 90 for jeans, rounded points for fine fabrics... get a few sizes. Your manual should provided you with clues to the right needle for the fabrics. (BTW... there really is no such thing as a Universal Needle... toss it.)
2. Re-read your manual and carefully follow the instructions on threading the bobbin and the upper thread...
3. Check your tension on the upper thread... it is too loose for the application. The tension on the bottom thread is handled by a spring on your bobbin case or race. If you do not have that threaded properly you'll have problems. Same with the direction the bobbin turns... have in it backwards... problems.
Barring all these things... It might be time for a qualified Singer repair person to look at it. Sadly Singer has seriously lowered it's standards in the last 20 years.
