Panasonic PT-47WX49 47" Rear Projection Television Logo
Posted on May 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is green all through the screen and i have adjusted every thing and it will not go away
All through the screen every thing's green. Ive tried to adjust every freaking thing and it wont go away. All the darker colors are green too.. What do i do????? Help!!!!!!
  • Anonymous May 11, 2010
    Its a projection?
Benny Freeman
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 165 Answers
  • Posted on May 07, 2009
Benny Freeman
Expert
Level 2:
Cheetah:
Answers
165
Questions
0
Helped
77944
Points
302
Have you connected the wires on the back properly?
3answers
Green tinted Screen, Please Help
My tv did the same thing try unplugging the cables and plug them back in and if that don't help you will have to buy a new set my set got fried in a lightning storm :,(
Kp57hw40 is a greenish color
If green appears to bleed out of objects then it's probably the saturation level is to high. If that doesn't work you can try changing the Hue setting more towards red and away from green.
If neither works and you don't have a warranty I would call your a local TV repair company.
Picture is pink in places and dark scenes the picture is mostly green
Oh dear.
It sounds like you have magnetised the screen by placing something magnetic too close.
Your only hope is to unplug the TV, and remove ANYTHING magnetic away from it, such as speakers etc. Give it a few hours then retry.
If this has been going on some time, it will already be too late.
The other possibility is the tube could be going!
Green convergance wont adjust, bowed screen
Green really shouldn't be adjusted, you adjust red and blue to the green. When a color is bowed that indicates that a part or two are bad, probably the convergence output IC's and possibly a fuse or fusible resister. You may need a tech to come adjust it for you because after replacing IC's the adjustments should be done in the servicers menus not just in the consumers menus.
Ink problem
You need to go to HP.com and download updates. Sometimes the all-in-ones will need them after adding new ink. Also stay away from generics inks they will cause problems. Hope this helps.
1helpful
The TV shows light green ring line on the screen.
Take off the speaker grill and the particle board just behind it. You'll find a block with six knobs. The 3 bottom knobs can be adjusted ever so slightly to fix your problem. Do it very slowly. You wan to adjust the center knob for green. Turn it until the lines go away. But again, do it very slowly. You're adjusting the voltage to the green tube. Do it too fast and you can damage it.
2answers
Green shadows surrounding bright whites
finally a consumer that gives us plenty of info :)
sounds like an overdriven green tube, the only thing you can try is to find the G2/Focus block assembly, either behind front speaker grill or remove back of set and look for a black box approximately 5"X5" , this box will have 6 philips type adjustment screws(plastic) 3 are for focus, do NOT adjust these,
the other 3 are marked "screen" the center screen adjustment screw is for green, turn it VERY slowly counterclockwise while the set is running and pray that your problem dis-appears, be advised that this is a HIGH VOLTAGE device so one hand in your back pocket the other hand turns the screwdriver, if the problem does not go away you have a poor green tube, good luck, sorry I can`t give you the exact location of the G2/Focus block, manufacturers move them to different places every year.
Sonykp-65ws510 convergence problem
Go to front of TV remove front bottom there you will find the focus and screen Block it has 3 on top and 3 on bottom This is to adjust screen drives and focus for each Tube R/G/B. also in front of ICs check your pico fuses they will look like resistors will be Green or yellow make sure they are good if opened they can cause your problem as well.
SLIGHT GREEN TINT TO PICTURE
most atimes if i adjust the screen adjuster on the voltage multiplier i always observe that the screengoes green(lg 21" television),and if i readjust the screen,the greengoes off.Rubberhead,try adjusting the sceenknob on your voltage multiplier(line transformer).
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
