Check and replace damaged components at its audio output stage circuit. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
SOURCE: cant find audio out jacks
This TV has a headphone jack on the side (above the Side AV input), a digital audio output (SPDIF) in the main input/output panel (bottom facing down) and two pairs of +/- terminals for right and left speakers. The terminals are to the left of the power cord. The SPDIF port is between the PC in and the AV3 in.
The terminals are used for directly wired speakers. Usually these have a pair of flat wire cables and the ends may have different color insulation (red, black, white, white/black striped).
If the speaker bar uses RCA inputs then get a 3.5 mm (M) to RCA (2 female) adapter for use with an RCA audio cable or an audio cable with 3.5 mm M on one end and 2 RCA plugs on the other. Plug the 3.5 mm end into the headphone jack of the TV. If you use the headphone jack, the TV speakers will probably turn off automatically. For the other audio options, you will need to enter the menus to adjust the settings. Press Menu and then go to Sound for speakers attached to the terminals. Digital Audio is adjusted from the Installation Menu then go to the Source Menu.
If the sound bar has a digital audio input, you should use that SPDIF cable (not usually included with the sound bar or the TV).
For details and a picture of the jacks, see http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=37PFL5322D/37&slg=en&scy=US for the User's manual or the leaflet (both include diagram). The User's manual has the picture on 3 (Section 2:2).
I hope this helps.
SOURCE: My 37PFL5322D 37" LCD has no picture and no
Pictures in my albums and my guides may help you out also.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: Model 37PFL5322D/37 phillips tv has a fast clicking sound in the power supply, what will cause this.
possible the main relay in the power supply board may need soldring or you could have a stickey relay
