How to I record something from the VHS side to the DVD? Keeps showing DVD as "error"
A DVD player does not have a record capability. In order record you must have a DVD Recorder.
Convert VHS to DVD via PC and software
What you need:
An analog converter device, VHS to DVD tutorial: analog converter
A PC with a DVD drive, DVD burning software (take Leawo DVD Creator as an example).
How you do it:
Step 1: Usually the converter has a USB portal on one side and red, white and yellow RCA cable on the other side. Connect the cables according to the colors and connect PC through the USB port.
VHS to DVD tutorial: connect converter
Step 2: Now you should be able to play the VHS footage on your computer, and this is when the Screen recorder come into play. Capture the screen while your VHS footage plays on your computer and storage it as a MPEG file (best MP4).
Step 3: Open Leawo DVD Creator and import the MP4 video you have just captured.
Step 4: Click the big green icon Burn to call out DVD burning panel.
Step 5: Enter the DVD burning setting panel and set the saving location. Then you could start to burn.
Hope this is helpful for all those with this same issue.
