Your initial settings may have been lost if you didn't back them up in an mmc card using the top slot compartment of the phone sorry! Whenever you remove your battery from the phone for more than 2-3 mins the phone goes to a default reset mode and on start up will start to re-install all the default features including the Arabizer which is due to the fact that the phone was designed in the UAE,you however can reject this installation whenever your default startup commences,and still enjoy your phone.
If you have an mmc card then after the phone has fully rebooted at default settings. Go to the phone settings page and select the "phone backup" option this enables a restore or backup option.If you have already backed up the data before, click on restore.All your settings will be restored.If not you will need to make new settings for your phone and then back them up this time.
Also for your phone contacts there is a "permanent restore option" at the "Phone settings" display. click on this option after you have entered your phone details and it will permanently save all your phone nos regardless of any kind of reset.If you did'nt do this earlier i'm sorry,your phone nos are lost also.
Whenever your phone stars to install the Arabizer suite,that usually indicates a default start setup process,which only happens on a total reset mode or removal of the battery from the phone for some minutes,meaning that if you didn't backup your data in an S.D or elsewhere before the incident,then i'm sorry your data are gone for good.You probably need to check if your battery is o.k, and alawys backup all your data on the S.D card.
