SOURCE: Flashing light on WD 500GB External Harddrive
This may sound silly,but sometimes if you put the drive in the freezer overnight it will work long enough for you to retrieve your data.Make sure you are ready to copy the data to another as it will likely fail again once it warms up.
SOURCE: My I Mac doesn't recognize the WD 500GB external drive anymore
it must be initialised /mounted 1st for osx
SOURCE: WD 500g hard drive computer cant read it
Is your hard drive power-up?
Do you hear your hard drive just spinning?
If so, your PCB may went bad. If you hear the hard drive clicking then your PCB or the heads went bad. If you need the data, you might have to ask the data recovery guys to get them back for you or find the PCB on Ebay.
If you don't care about your data, send it back for the warranty replacement
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
SOURCE: WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window
click on Disk Management, on the right side, right click in the USB
Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
