LG HBM 730 Bluetooth Headset Wireless Headset Logo
Posted on Oct 09, 2007
Broken ear peice
My over the ear piece is broken. Where can I find a replacement /
  • Anonymous Nov 12, 2007
    I have the same problem....tried to Superglue it back in place, that didn't work either.
  • dsquirrel Jan 19, 2008
    My ear piece broke - went to two Verizon stores and they basically said sorry with no help.
A
Anonymous
Visit nearest Verizon store that has a repair center and they will usually replace it for free. I did this and they actually exchange the whole headset for a new one. They were just out of the over the ear piece. Hope this helps.
Rubber holder that goes over the ear has broken. Can it be replaced and how? Bluetooth still works find.
Hi cptpatterson,
  • If you have the rubber holder broken , then you can stick it carefully with superglue and it should work fine, but make sure that the glue does not go in the ear piece which can affect the ear piece and would not work properly.
  • There are spare rubber holders available at an authorized Nokia Shop from where you can get it , but I would suggest if you want to save money you can just use super glue in small quantity and use it at the broken surface and it will work find for you as this device does not need a huge amount of strength that it has to bear.
Hope that helps..:) Let me know in case you have any queries, your feedback would be appreciated.
Ear peice broken
NO,sir basically Ear peice is not repaired
1helpful
Y lg chocolate touch will no longer ring and I also cannot get text alerts. It will still vibrate for a ring and for a text but no sound. I can hear on the ear piece for phone calls fine. Is my speaker...
hello jaminii4 the ear peice may be stuck on your phone. 1 take the battery out of the phone 2clean the contacts on yout phone, next send yourself a txt meddage. if yout still having ptoblems their is a section on yout phone in your in the serrings. It is the default setting for your phone dod mot do the testore phone it will wipe out your phone. thr security code is the last four digits on your number ok hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Jawbone earpeice broken
I had the same problem. I used a tiny jeweler's screwdriver to push it out from the bottom hole.
I have a set with one ear piece working
I don't have one, but are you sure the ear piece itself is bad? Usually, the problem is in the plug, cord, or termination at the ear piece. Troubleshoot with an ohmmeter (pocket DMM has one) and repair with a soldering iron.
Ear peice problem for nokia5800xm
Probably not compatible with your phone. Try getting a new ear piece or your phone might have a software issue.
3helpful
Over the ear piece broken on my hfblu-1k cellular
You can get replacements by calling 1-732-912-2000 and follow the directions on the menu. Listen to the choices and you should be good to go. Ask for Tech Support # 216.
Mar 08, 2009 • Cell Phones
3answers
Broken earhook
sadly there is no replacement part for this, you can only use a super glue that you can buy in home depot to fix this, just a small amount and let it dry
Broken on/off switch
need to replace the on/off switch for this camera. I have the broken piece that cannot be repaired. How can i find a replacement switch. I can repair the camera myself with the new switch. thanks.
Top LG Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
