I am getting a Ld code during the rinse cycle
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
If it is not a slow drain or drain pump, you could try this.. . . Make sure the tube that goes to the pressure transducer is not plugged or damaged. .. . . . ...Do a "Test #6 Water level and pressure transducer calibration."............... . . . . . . . . . . I found the document 8567037 Rev A inside the washer. Followed the instructions to enter manual diagnostics. If anyone else wants to do this... follow these instructions. Make sure your washer is EMPTY. No laundry or water. 1. Start with the washer off. 2 Press and hold any button (except the power, start, or stop) for three seconds - let off for three seconds -press for three seconds - let off for three seconds -press for three seconds - let off. 3. then when it starts to beep and flash press it momentarily one more time. This should get you into the Manual Diagnostics mode. You should have a 00 on the display and the add garment led should be flashing. 4. Press and hold the Cycle Signal button until is beeps and a Pt is displayed. 5. Press stop or power button. 6. verify your water level when you fill next time. . . . . . . . . . . . . . . . . . . . . .
