1. You might have to enter a PIN code to unlock this screen. Enter the PIN/CODE set by you or 0000(also try 1234) if you have not yet changed the default PIN.
2. Its easy, first press the MENU button on your universal remote and go to Settings->Child Lock/Parental Control/Security. You might have to enter a PIN code to unlock this screen. Enter the PIN/CODE set by you or 0000(also try 1234) if you have not yet changed the default PIN.
RCA TV Parental Reset Code: First select parental control from the menu. You will be asked to enter your password. Press and hold the "volume +" and "channel +" buttons on your television (not the remote) for 8 seconds. You will see a message that the parental controls have been unlocked.
No other way. You should have its remote control to select inputs. I thinks that I've answered this problem, many times before.
If you post any more, please provide the name of yours with the post, so that I do recognize you and not to respond it, and allow any other to answer you.
Here I see this problem is posted by some 'Anonymous" person.
Whatever it may be, you can't select the input to your Sinotech TV; without its remote control.
These are the steps to unlock Apex TVsApex TVs have parental locks that allow you to block certain
programs based on their rating. When this
feature is no longer needed and you want your TV to display all programming no
matter its rating, you must unlock your TV. Unlocking your Apex TV is done
completely from your remote control and does not require any tools. The process
takes less than 5 minutes. • Press the
"Menu" button on the remote control and use the arrow buttons to
scroll down to the "Parental Guide" option, then press the
"Enter" button. Type in the default parental code "6688" if you have not
set your own code. If you have set your own code, type it in. If you set your
own code and forgot it, override it by using "6688." Use the arrow keys to switch the parental lock to "OFF."
This allows all programs to be viewed no matter the rating. Press the
"Exit" button on the remote and start watching all your channels.
If you forget your password, press and hold TV on the remote and the MENU button on the television simultaneously for 3 seconds. Parental controls will then unlock and you can re-enter a password via Lock Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password. OR TRY THIS.. Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
Bill
Need two unlock the parental control on the PS3
