Boating Logo
Posted on May 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Evinrude outboard motor starter rope
Starter rope on a evinrude outboard motor 9.9 hp has been replaced when bolt is tightened rope hard to pull out and will not return
  • rustystones May 11, 2009
    many thanks washer under spring had dislodged
  • Anonymous Mar 27, 2014
    I cant determine the year by the online description because it does not have a model # on the identification plate
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on May 08, 2009
Anonymous
Expert
Level 2:
Answers
65
Questions
0
Helped
35899
Points
134
Most likly is missing a washer,has been reassembled incorrectly.take apart and check
My 9.9 Evinrude outboard will not start. It is electric start. There is noting when I turn the key. I checked the battery even swapped it for a new one. Still nothing.
Will it rope start? Do you hear the solenoid engage at least? If it rope starts, recheck all electrical connections. They need to be clean. corrosion can interrupt circuit. Then check solenoid, finally starter motor.
1helpful
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
How to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Nov 01, 2015 • Boating
How i thread my pull cord on my 6.0 HP outboard evinrude
How old? If it is the old system that looks like a spiral ramp, very carefully. I knot one end, feed it into the hole at the top and then feed it around without taking apart the starter. The spring is a pain to work with.
15 hp crysler outboard motor pull start diagram
You will need a special tool to do that job. It is just a 10/24 long bolt bent to form a crank and a nut spun on it and soldered or double nutted to keep it in place.
Remove the top slotted bolt and replace it with the tool.
Release the pressure on the cross pin by back winding the spring- and remove the cross pin.
The starter gear will slide up the shaft after you remove the flywheel. Or you can loosen the 2 screws on the top bracket.
Now release the tension on the spring and pull the core from the spool.
The spool comes out and the rope must be freed from the guide.
The reverse is about the same- feed the cord and spool it up attach the handle.
Replace the top bracket if you removed it. Put on the starter gear
grease the spring with light grease inspect the nylon base and coil anchor (tiny brass cinch squeezed on to the stub of spring coming from the base.
Now -with the tool- wind the spring backward about 5 times and insert the pin thru the gear and into the shaft. With the tool in place pull the starter thru several times to see if the tension is right and you didn't forget the rope guide..
Replace the original screw to hold the pin in place.
This works for most pop-up starters.
It is a 1982 4hp outboard evinrude what is the start sequence
Open the fuel valve ( at the back near the spark plugs).
Pull the choke knob ( SB side at the lower front of the motor)
Set the throttle handle in 'start' position ( abour 1/4 of the travelling way from SB to Port)
Pull the rope starter.
Should start easily.
Nov 05, 2017 • Boating
6helpful
How do i remove starter on 2001 ford f350 dually (7.3 l powerstroke)
Starter
Removal & Installation 1. Disconnect the positive and negative battery cables.
2. Raise and safely support the vehicle.
3. Remove the starter terminal cover.
4. Remove the terminal nut and separate the battery starter cable from the starter motor.
5. Disconnect the solenoid (S) terminal connector, if equipped with a starter mounted solenoid.
ø To disconnect the hard-shell connector from the solenoid (S) terminal, grasp the plastic shell and pull off; do not pull on the wire. Pull straight off to prevent damage to the connector and (S) terminal.
6. Remove the starter motor retaining bolts.
7. Remove the starter motor from the vehicle.
To Install:
8. Place the starter motor in position and install the starter motor retaining bolts. Tighten the bolts to 15-20 ft. lbs. (20-27 Nm).
9. Install the battery starter cable and a terminal nut to the starter motor. Tighten the terminal nuts to 79 inch lbs. (9 Nm).
10. Connect the solenoid (S) terminal connector, if equipped with a starter mounted solenoid.
11. Install the starter solenoid safety cap. If equipped.
12. Lower the vehicle.
13. Connect the positive and negative battery cables.
14. Start the engine several times to check starter motor operation
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
