Hi! To change the battery for a Babyliss Pro FX760 hair trimmer, you will need to follow these steps:
- Make sure the trimmer is turned off and unplugged from the power source.
- Locate the battery compartment. This is typically located on the bottom or back of the trimmer.
- Remove the battery compartment cover by pressing the release button or sliding the cover open.
- Remove the old battery by gently prying it out of the compartment using a flat-headed screwdriver or a similar tool.
- Insert the new battery into the compartment, making sure it is oriented correctly and seated securely.
- Replace the battery compartment cover by sliding it back into place or pressing it down until it snaps into place.
- Plug in the trimmer and turn it on to test the new battery.
It is important to note that the specific process for changing the battery in a Babyliss Pro FX760 trimmer may vary depending on the specific model and design of the trimmer.
Note: The battery in a Babyliss Pro FX760 trimmer may vary depending on the specific model and design of the trimmer.
