Miller bobcat 225g plus starts fine runs great will not idle down and also will only weld cranked all the way to 225 ,the arc im getting is if it were set at 130 but it welds that great whats up
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
a simple question why can't I get a direct answer? can I use arc welding machine 220v on cars? yes/or no?
BobCat Pioneer 1200 manual
