Motorola Mobility E815 Logo
Posted on Oct 08, 2007
Motorola E815 alarm quit working
Motorola E815 cell phone with 5 internal alarm settings - have 3 currently set and as of today, has stopped working. On previous phone, when the alarm time came, the clock on the phone just skipped the minute the alarm was set for; ie. if alarm was set for 1:33pm, the clock jumped from 1:32pm to 1:34pm. This is the 2nd E815 phone I've had that has done this. Please help!
A
Anonymous
I've had a similar problem with alarms not going off.  In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off.  Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes.  The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
I have a Motorola E815 Alltel cell phone and was wondering if I could somehow make this phone compatible with Verizon since they are my current carrier? How do I switch this Alltel E815 to Verizon?
Hi Dawn Lynn Martens,
You can take the device to Verizon to see if they can activate it with their frequency. Since they handle CDMA devices as the Motorola E815.
Best Regards,
Katya
Motorola Support
I have a Motorola E815 phone. The screen looks scrambled.
take out the sim card and format or restore to fabrik settings
Set all 3 alarms and they never go off. Big problem since it is my only alarm clock for work and just recently quit working have used for almost 2 yrs
You need to make sure the Ringer is enabled. Here are the instructions:
Alarm Clock
The Alarm Clock tool allows you to set up to three
alarms.
When you set an alarm, the current time is displayed.
When the alarm goes off, Alarm 1 (or 2 or 3, as
applicable) will be displayed on the LCD screen and
the alarm will sound.
1. From standby mode press the Center Select
Key c [MENU], then press the Directional Key
r right twice for SETTINGS & TOOLS, 2
Tools, 4 Alarm Clock.
2. Press the Directional Key j up or down to
highlight an Alarm (1, 2, or 3), then press the
Center Select Key c [OK].
3. Enter the alarm information including:
• On/Off
• Time
• Frequency
• Ringer
4. Press the Directional Key j up or down to
highlight the information you want to set, then
press the Left Soft Key L [Set] to view your
choices.
5. Set information and press the Center Select Key
c [OK].
6. Press the Center Select Key c [SAVE] after
setting all of the applicable Alarm Fields.
2helpful
Motorola e815 Verizon Phone Won't Make Calls
restore your phone settings and try it
Motorola E815 External Speaker
I was able to solve this problem by locating a suitable speaker on eBAY.
eBAY was the only place I was able to find a replacement speaker for my cell phone.
It seems that Verizon (my cell phone provider) and Motorola only offer one solution to this problem - buy a whole new cell phone (which means signing up for another 2 years of Verizon wireless service). My solution was better and cheaper (only cost me $7.00 to buy it and have it shipped).
This has been the only problem I've ever had with this cell phone and the new speaker solved it.
Motorola E815 alarm full
At the alarm screen, highlight one of the alarms, then press the main menu button, several choices, including a delete option will be given. There is even a delete all option
Motorola E815 flashed to Cricket
you need to get that charging port repaired. www.fixphonenow.com can replace the charging port with a new on for $55.
Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
2answers
This exact issue happened to me: I left my phone off for 2 days (unplugged), turned it back on and the internal speaker started working normally again. The phone worked normally for over a month after this. Yesterday, the earpiece speaker stopped working again after the phone fell out of my pocket. I suspect a loose connection or something similar, but I've had my phone off for the last day and will let you know whether or not it starts working again.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
