I have a blackberry pearl 1800 and I can't get my sim card to work in it. how do I unlock it to make the sim card work?
How To Enter the Unlock Codes on a BlackBerry Cell Phone
Model : All BlackBerry Models (except T-mobile)
1 - Using the menu go to Settings Menu -> SIM card press select.
2 - While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Model : T-mobile BlackBerry Models
1 - On the Home screen, click the Tools icon. The Options screen appears.
2 - In the tools screen, select the Settings icon.
3 - Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 - Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 - Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 - Input the Network Unlock code
7 - Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 - While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 - Choose “Advanced Options”.
3 - Select “Sim Card”
4 - There is no area to type these letters, you just type them as
instructed. No need to hit keys twice to get a letter either. Type m e
p p d to display the first five levels of SIM locking. Most companies
use network locking so the Network should display Active. All other
states should display Disabled ( you will not see text appear on screen
while typing )
5 - Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 - Input the SIM Unlock code
7 - Press in the trackball in once
Your phone is unlocked
Option # 3: T-Mobile or Cingular, your carrier
Yes, you can ask your carrier for an unlock code for your Blackberry
and guess what, they do it for it Absolutely FREE. So, what is the
catch? The only condition which atleast T-Mobile imposes on its
customers before it gives out the unlock codes for the Blackberry Pearl
or any other cell phone is that you have to be under the contract for
atleast 90 days or 3 months before they can give you the unlock code.
So, if you have the patience, I would recommend that you wait for this
3 month time frame before calling up 611 from your T-Mobile phone, talk
to customer service and get your unlock codes.
In my search for the Blackberry Unlock codes, I found out that a lot
of people mess up before they have no idea how to enter the unlock
codes correctly. So, follow this method to enter your Blackberry Unlock
code
Please rate my solution, thank you.
That's simple. You can unlock blackberry pearl network carrier with blackberry unlock code. This code will reset your phone network to default factory setting and you can purchase that code at third party sites on internet.
To unlock the blackberry first you need to get th e unlock code from the previous service provider.after entering the unlockcode you can use your simcard
what is the mep code for it?
