When turning on the xbox the screen turns pink
OK did you ever try to hack your system did you open the inside of it did you drop or smash it or leave it in extreme temps if not it might be the result of poor cable connection,first turn off your Xbox 360 and check out the cables that are connected to the system. Remove them and re-connect them firmly. Now switch on your Xbox 360 again. There is a good possibility that you will find the fuzzy purple screen gone. If you still find a fuzzy purple screen then this might be a bit more complicated problem that your system is experiencing. Usually system overheating is one of the major reasons that cause various Xbox 360 errors
SOURCE: when I turn on my xbox 360 I get sound but only a
this seems like a component cable issue, are you connecting the system to an hdtv? if so check the component connections to make sure its connected to the proper ports.
