I was actually trying to follow the advanced manual to figure out the camera in more depth, and I must have mis-set something. Now I can't even take a photo with it as the shutter won't work. The viewfinder is fine and shows images; I have a new SD card and batteries, but can't take any pictures. (I don't really get along well with icons and digital menus, in anything!) Please explain what I have set improperly. Thanks.
When you depress the shutter button halfway, you are (in fact) activating the focus mechanism.
If in AF mode, you should hear the 'beep' when focus is achieved.
However, bear in mind that the XSi has three focussing modes: Quick mode, Live View, and Manual. There is a difference in how focussing is achieved between the Quick and Live View modes. (see page 102 onwards of the user manual "using AF to focus").
Also, the barrel of the lens will move during the focus operation.
If this does not happen, then there is a definate problem.
Having images in focus despite having no movement on the lens, simply means that the aperture settings are probably small enough to give sufficient depth of field to include your subject.
Hi LLFraserny, You can probably try to isolate the error 99 first. To isolate the cause of the issue, do the following: 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 30 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the “ERR 99′ message appear? If it does, then the camera will need to be serviced. If the message does not appear, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced. One last item to check before sending camera to Canon service is the alignment of the shutter. Life the mirror and visually inspect the shutter curtain. If each segment is not completely straight, touch it lightly with your blower bristles and try to pop it back into alignment.
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
To isolate the cause of the issue, we suggest that you do the following:
3. Allow the camera to sit without power for approximately 20 minutes.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
camera body.
To isolate the cause of the issue, do the following: - 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert only a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: - 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: - 1. Turn off the camera. 2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
To isolate the cause of the issue, it is suggested that you do the following:
camera body.
In most film cameras, a battery is not necessary to manual advance film
using the lever. Your Canon AV-1 is no exception. I have owned two
cameras from the same group, the AE-1 and the Canon A-1. Neither
required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A",
otherwise the shutter won't release and the film lever won't work
correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
You can select the shutter speed in the following range
Shutter speed
15-1/2000 sec
ISO sensitivity
• Auto • ISO 80 • ISO 100 • ISO 200 • ISO 400 • ISO 800 • ISO 1600
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
