I HAVE BLUE DOTS SHOWING ON THE TV SCREEN. THEIR MULTIPLYING
The lamp eng it bad you need to replace the dmd or the hole thing the eng, whear the lamp in stall at and i done a lot of them to and that cost a lot 1000.00 plus the core you need to send back to mitsubishi you may whant to call them to see if it under wearenty if not that will till you how much it cost to have it replace..it a big job it chang them to about 2hours to replace them the lamp eng ..good luck i hope this help you out...me my self don,t like a dlp at all the lamp cost to much to replace for lasting just a year. lamp should last about 2 years but i not seen a lamp last that long at all..the samsung is just as bad... will good luck
SOURCE: screen shows white dots over entire screen 65 inch
Try cleaning the optical lens for dust if still the same DMD chip is defective and needs a replacement.
SOURCE: White dots are showing up on the screen. They are
This problems is the tv Projection Light Engine design flaw with it IC chip.These problems happen to many models of it DLP tvs Big Screen 60 and up.Mitsubishi,Samsung,Sony,Toshiba all used the same IC chip on their 60 and up on their DLP tvs Big Screen.Tries make deal with Mitsubishi help u split the cost of repair the tv Projection Light Engine by replacing the IC chip or replaced the entire Projection Light Engine system.This problems is not new,been going on for a few years.Many people when on Youtube **** about this problems with white dots showing up on their tvs screens and multiplying rapidly.
